- Opel
- Astra, Cascada & Kadett
- Astra J & Cascada
- Von Navi 600 Navi 900 machen kostenlos
Habe gelesen on
http://www.insignia-enthusiast.org/forums/index.php?showtopic=8094
Muss erst regristrieren hier um zu lesen
Es soll möglich sein mit software dass navi 600 ein 900 navi zu machen : hier die text :
You need:-
* An empty USB memory stick (formatted to FAT32)
* A blank CDR
It will wipe radio presets, address book, and saved destinations.
1. Download these two files:
http://opel-club.ru/files/navi_600_900_rus_fix.rar
http://yadi.sk/d/lmhsKgwO4crXM
2. Burn the ISO file to the CDR and copy the contents of the ZIP file to the root directory of the memory stick.
3. Go out to the car and switch on the navi system (ignition on or off doesn't matter), remove the SD card, and insert the memory stick. Follow instructions - it will fail at about 80%, this is expected.
4. Remove USB stick, insert CD, and switch unit off and on. This kicks you into the bootloader where it then proceeds to flash a load of stuff from the CD. Takes about eight minutes.
5. Reinsert SD card and let navigation initialise.
6. Reinsert memory stick and repeat installation - it'll work this time.
7. Give the system a chance to reboot a few times and it'll wake up to be a Navi 900.
Basically, the Navi 900 is set up to respond to voice commands (to choose radio station, for example) but our SD card is missing the voice files. So hitting the voice command button pops up a message saying that the language packs aren't installed. However, if you're on the phone screen, voice commands are routed to the bluetooth module and work normally.
Sie auch :
http://cruze-forum.de/viewtopic.php?f=14&t=3699
Navi 600 und Navi 900 : Hardware soll 100% identisch sein
Ich denke, Flashen ist immer ein Risiko
Aber viele habe es gemacht nach diese Foren
Jemand schon getan beim diesem forum
Grüßen aus Holland
Spricht man mal über die (sichere) Demontage von Airbags oder nutzen von OP-COM Clonen wird man fast geblockt, aber Threads über Illegale Software sind erlaubt?
Ich mein mir ist es egal, ich nutze auch viel illegales, aber da sollte die Moderation mal lngsam wissen was sie will.
Kauft euch den Mist und fertig...dann wundern sich noch alle warums Opel so schlecht geht.
341 Antworten
Wenn du mal an den Anfang dieses Threads guckst, kannst du meine Meining/Sorge mehrfach lesen...
Scheinbar ist das Theme eben mehr als ein paar andere Grafiken.....
Ging eben in die Hose und Montag gehts zum FOH...
Bin mal gespannt was der fürs aufspielen der Originalsoftware nimmt.
Wenns überhaupt funktioniert mit der Originalsoftware. Es wäre nicht das erste Gerät was beim Flashen die Flügel gestreckt hätte. Habs vor einigen Jahren bei einer FritzBox erleben dürfen. Hatte sie versucht zu flashen und dies ging schief. War nur noch ein Haufen Elektronikschrott.
Hast du mal versucht, den USB-Stick nochmal zu formatieren, die Datei nochmal zu downloaden und dann es noch einmal zu testen?
Schau mal ob dir die Datei hier weiterhilft (Erklärung und das Passwort für den Download sind im Text):
http://www.boerse.bz/.../...pel-navi-600-mach-ein-opel-navi-900-a.html
Ich bin leider gerade am iPad und kann nicht schauen, ob beide Dateien gleich groß sind oder ob diese sich unterscheiden...
In dem russischen Thread steht alternativ ja noch, dass man falls etwas schief geht, den verlinkten Patch dort ausprobieren soll. Vielleicht kannst du das auch mal noch testen.
Die letzte Variante ist, dass du mal testest, ob du die Version vom 900er drauf machen kannst und dann entweder lassen oder auf das 600er wieder downgraden kannst.
Mehr schief gehen kann ja nicht und zum Händler musst du so oder so. Vielleicht hilft es dir ja auch und es geht wieder.
Gibt es hier denn wirklich jemand, der die 600er Software drauf hat und das Theme so ändern konnte?
Ich drücke dir die Daumen!!!
Naja... es funktioniert alles... kackt eben "nur" alle 2 Minuten ab und fängt von neu an -.-
Ich versuche jetzt mit der Hilfe von eraser das hinzubekommen via Flash auf 900...
So... also nach Austausch der Dateien (gleiche Voraussetzungen) mit eraser hab ich eben versucht die 900er Software aufzuspielen, aber wie bereits erwartet, erkennt er die Update-Routine nicht, beim einstecken des USB-Sticks (3 verschiedene ausprobiert)
Selbst wenn ich die CD einfach mal einlesen lasse, passiert nüscht.... manueller Neustart führt nicht zum Boot in den Bootloader....
Also hilft nur der Weg zum FOH..
Halte euch auf dem Laufenden und drücke euch die Daumen, dass ihr mehr Glück habt, egal ob Upgrade oder Theme-Wechsel :)
ja sorry verstehe das auch nicht warum das nicht geht komisch
hier steht es auch das es geht http://translate.google.com/translate?...
Jede Wette, dass dein FOH damit überfordert ist. Ich drücke Dir trotzdem die Daumen!
<hehe> meiner ist schon damit überfordert eine anfänglich fehlerhaft durchgeführte BC-Verbrauchskorrektur durch zu führen. Die Mathematik dahinter sticht mir langsam ins Auge, nur der "Schrauber" will auf meinem Wink mit dem Zaunpfahl nicht anspringen. Nun habe ich die Bremse gezogen und gesagt das keine Hand mehr angelegt wird ohne zuvor bei Opel anzufragen wie man den Fehler korrigiert.
Ich sehe schon wie es heißt "FW einmal komplett neu drauf, dann neuer Korrekturversuch".
Hallo zusammen. Ich habe aus meinem 600er ein 900er gemacht. Hat nach Image brenntechnischen Problemen auch funktioniert. Danach habe ich auch ein neues Thema draufgemacht. Wenn ich das bei den Russen alles richtig gelesen habe, funktioniert das auch nur in dieser Reihenfolge. Also erst auf 900er upgraden und dann das neue Thema.
Theme nicht Thema
Original geschrieben von dgl16
Theme nicht Thema
Should we Change over to english right here?
Theme nicht Thema
Theme (eng. ), Thema (ger.)
EDIT: Da war Astradruide schneller. ;)
Original geschrieben von DerKleineChris
Original geschrieben von Philip92
Hallo kleiner Chris,
hast du es schon getestet, ob es nach der Anleitung funktioniert, dass man die Themen ohne die Software für das Navi 900 installieren kann?
Vielen Dank und viele Grüße,
Philip
Hey :) ja klappt völlig problemlos! Sieht absolut geil aus.
Sonniger Gruß
Chris
Hätte ja auch bei mir klappen können xD
Vertrauensvoll naiv gewesen... Mal gucken wie hoch die Rechnung wird -.-
Jaja, ist schon so eine Last mit dem Neudeutsch ;-)
(Das erschreckende ist dagegen das ausländische Teilnehmer wiederrum für ihr mässiges Deutsch schnell Pfeffer auf MT bekommen.)
