- Opel
- Astra, Cascada & Kadett
- Astra J & Cascada
- Von Navi 600 Navi 900 machen kostenlos
Habe gelesen on
http://www.insignia-enthusiast.org/forums/index.php?showtopic=8094
Muss erst regristrieren hier um zu lesen
Es soll möglich sein mit software dass navi 600 ein 900 navi zu machen : hier die text :
You need:-
* An empty USB memory stick (formatted to FAT32)
* A blank CDR
It will wipe radio presets, address book, and saved destinations.
1. Download these two files:
http://opel-club.ru/files/navi_600_900_rus_fix.rar
http://yadi.sk/d/lmhsKgwO4crXM
2. Burn the ISO file to the CDR and copy the contents of the ZIP file to the root directory of the memory stick.
3. Go out to the car and switch on the navi system (ignition on or off doesn't matter), remove the SD card, and insert the memory stick. Follow instructions - it will fail at about 80%, this is expected.
4. Remove USB stick, insert CD, and switch unit off and on. This kicks you into the bootloader where it then proceeds to flash a load of stuff from the CD. Takes about eight minutes.
5. Reinsert SD card and let navigation initialise.
6. Reinsert memory stick and repeat installation - it'll work this time.
7. Give the system a chance to reboot a few times and it'll wake up to be a Navi 900.
Basically, the Navi 900 is set up to respond to voice commands (to choose radio station, for example) but our SD card is missing the voice files. So hitting the voice command button pops up a message saying that the language packs aren't installed. However, if you're on the phone screen, voice commands are routed to the bluetooth module and work normally.
Sie auch :
http://cruze-forum.de/viewtopic.php?f=14&t=3699
Navi 600 und Navi 900 : Hardware soll 100% identisch sein
Ich denke, Flashen ist immer ein Risiko
Aber viele habe es gemacht nach diese Foren
Jemand schon getan beim diesem forum
Grüßen aus Holland
Spricht man mal über die (sichere) Demontage von Airbags oder nutzen von OP-COM Clonen wird man fast geblockt, aber Threads über Illegale Software sind erlaubt?
Ich mein mir ist es egal, ich nutze auch viel illegales, aber da sollte die Moderation mal lngsam wissen was sie will.
Kauft euch den Mist und fertig...dann wundern sich noch alle warums Opel so schlecht geht.
341 Antworten
Kann mal einer erklären wie das mit der Start Animation funktioniert
Danke M.
Wie wäre es mit einer Anleitung für das Theme?
Habe das 600er und möchte. nicht . auf die Software vom 900er wechseln..
Das wäre auch 'ne Sache, die mich interessiert! Hab gerade meine Garantie verlängert..Softwaretechnisch will ich nichts verändern. Aber eine andere Theme wäre schon geil :D
Original geschrieben von ice20051
habe das Upgrade auf von 600 auf 900 auch gemacht, aber jetzt nur Probleme.
1. Beim Update via USB-Stick , kein Abbruch bei 80%, lief komplett durch
dadurch konnte ich die CD nicht einlegen
2. Fahrtenbuch ist installiert, 3D Ansicht usw. auch, kann aber nicht genutzt werden. Navi schaltet sich nach 2 min IMMER aus und wieder ein, danach sind die Standardeinstellungen wieder drinnen (2D Ansicht usw). Auch nach 1h Rebooten immer wieder Reboot
3. Der USB-Stick wird jetzt auch nicht mehr erkannt, weiteres Update also nicht mehr möglich.
Wer kann helfen? Flashen wurde mit der Anleitung hier im Forum durchgeführt
Ice
Hab genau das gleiche Problem... Habe aber nur ein Theme aufgespielt. Radio geht nach 2 min aus/an und USB wird nicht als Update erkannt.
Hat jemand eine Lösung?
Du machst dir sorgen um deine Garantie grins
Leistungssteigerung? Du hast normal jetzt schon keine Garantie mehr
Meine Leistungssteigerung wurde vom Opel-Vertragshändler gemacht ;) mit schriftlichen Beleg über den Erhalt der Garantie ;) sonst hätte ich's ja nicht gemacht :D
Kann es sein das er Dir eine Händlergewährleistung eingeräumt hat aber keine Herstellergarantie?
Die Herstellergarantie kann Dir nur der Hersteller garantieren. Wenn Opel ein Motortuning von irgendeinem Drittanbieter ohne Verfall der Herstellergarantie zulässt, darfst Du mir/uns ruhig nennen was man verbauen lassen darf.
Ich weiß ja nicht was aud dem Blatt Papier steht, aber manches geschriebene ist im Streitfall nicht das Papier wert auf dem es steht.
Ice
Hi ich nochmal,
CD lesen geht auch nicht mehr. Schreibt beim einlesen immer nur "CD lesen" MP3 auf USB-Stick und CD dagegen geht einwandfrei.
Ice
Das hat schon alles seine Richtigkeit wie ich es geschrieben hab! Ich habe vor knapp 4 Wochen die Leistungssteigerung machen lassen. 1 1/2 Wochen später hat mein Schalthebel angefangen sich im 1. und im 5. Gang zu bewegen..Lagerschaden..ohne Beanstandung auf Garantie gemacht und die Geschichte ist im Auslesegerät nicht zu finden! So wie es mir versichert wurde. ;)
Aber das tut nichts zur Sache.. meine Frage ist immer noch wo ich so Themen her bekomme und wie ich sie auf mein Navi600 aufspielen kann ohne ein 900er daraus zu flashen.
Chris
Ob es sichtbar war oder nicht war nicht Deine Aussage. Deine Aussage war das die Opelgarantie nicht erlischt. Ich behaupte einfach mal das Opel kein Tuning eines externen Anbieters ohne Garantiebeschneidung zulässt!
Die Antwort zu der "zugelassenen" Tuningmaßnahme bist Du damit schuldig geblieben.
...und ob eine FOH eine Tuningmaßnahme evtl. verschleiert hat nichts mit Garantie sondern Betrug zu Deinem Gunsten zu tun.
Sehe ich ähnlich ...
Hab ich kein Problem damit ;)
Könnt ihr das OT-Geblubber bitte woanders abhalten!?
Kleine Übersicht gibt's z.B. hier...
Endlich ein Beitrag mit dem ich was anfangen kann!! Danke dir
<Ironiemodus>
Stimmt, Du hast recht. Weil es OT ist werden in Zukunft vermeindlich falsche Aussagen nicht mehr kommentiert.
</Ironiemodus>
... dann stehen sie halt als "gegeben" im Netz der Wahrheit.
