- Opel
- Astra, Cascada & Kadett
- Astra J & Cascada
- Von Navi 600 Navi 900 machen kostenlos
Habe gelesen on
http://www.insignia-enthusiast.org/forums/index.php?showtopic=8094
Muss erst regristrieren hier um zu lesen
Es soll möglich sein mit software dass navi 600 ein 900 navi zu machen : hier die text :
You need:-
* An empty USB memory stick (formatted to FAT32)
* A blank CDR
It will wipe radio presets, address book, and saved destinations.
1. Download these two files:
http://opel-club.ru/files/navi_600_900_rus_fix.rar
http://yadi.sk/d/lmhsKgwO4crXM
2. Burn the ISO file to the CDR and copy the contents of the ZIP file to the root directory of the memory stick.
3. Go out to the car and switch on the navi system (ignition on or off doesn't matter), remove the SD card, and insert the memory stick. Follow instructions - it will fail at about 80%, this is expected.
4. Remove USB stick, insert CD, and switch unit off and on. This kicks you into the bootloader where it then proceeds to flash a load of stuff from the CD. Takes about eight minutes.
5. Reinsert SD card and let navigation initialise.
6. Reinsert memory stick and repeat installation - it'll work this time.
7. Give the system a chance to reboot a few times and it'll wake up to be a Navi 900.
Basically, the Navi 900 is set up to respond to voice commands (to choose radio station, for example) but our SD card is missing the voice files. So hitting the voice command button pops up a message saying that the language packs aren't installed. However, if you're on the phone screen, voice commands are routed to the bluetooth module and work normally.
Sie auch :
http://cruze-forum.de/viewtopic.php?f=14&t=3699
Navi 600 und Navi 900 : Hardware soll 100% identisch sein
Ich denke, Flashen ist immer ein Risiko
Aber viele habe es gemacht nach diese Foren
Jemand schon getan beim diesem forum
Grüßen aus Holland
Spricht man mal über die (sichere) Demontage von Airbags oder nutzen von OP-COM Clonen wird man fast geblockt, aber Threads über Illegale Software sind erlaubt?
Ich mein mir ist es egal, ich nutze auch viel illegales, aber da sollte die Moderation mal lngsam wissen was sie will.
Kauft euch den Mist und fertig...dann wundern sich noch alle warums Opel so schlecht geht.
341 Antworten
Der Astra besitzt einen Tiefentladeschutz, außerdem würde einem das Anlassen mit schwacher Batterie schon durch den Zusammenbruch der Bordspannung auffällig werden. Bei mir hatte sich durch das Vergessen ein defekter USB-Stick angekündigt ...
Schwache Batterie nach 3 Monaten? :/
Hm, okay. Danke :-)
Ob s am Stick liegt liesse sich recht einfach feststellen - MP3 CD Brennen - setzt er da sekundengenau wieder an wo er aufgehört hat ...
wie gesagt , am update kanns eigentlich nicht liegen - bei mir macht s keine Probleme , auch nicht nach 2-3 Tagen ..
Na mal wieder zurück zum ürsprünglichen Thema:
So wie es aussieht benötigt man für die Sprachsteuerung kein zweites Micro,
siehe Link und die 3 Seiten mal durchlesen, es wird wohl der VCI Code vom Opelhändler für das DVD900 benötigt, soweit ich das jetzt beurteilen kann.
grüße irgendwie
beziehst dich jetzt aber auf Navi 900 - oder ?
Ich stimme dir zu , bei verbauter Bluetooth Handy vorbereitung wird vermutlich nur ne Freischaltung wie von zb. Sprachsteuerung nicht vorhanden auf vorhanden erfolgen müssen , leider ist das nicht so einfach , oder der Opel Händler ist nen guter bekannter ... der auch nichts machen kann wenn ne Programmierfreigabe von Opel erfolgen muss ...- VCI Code halt
"Programmierung mit MDI erforderlich (kein OP-COM).
In manchen Fällen kann es vorkommen, dass die Programmierung per VCI Code erfoderlich ist.
D.h. der Opelhändler muss bei Opel einen VCI Code anfordern (eine Art Programmierfreigabe) und kann danach dann die Programmierung durchführen. In seltenden Fällen kommt es vor, dass Opel keine Freigabe erteilt. In diesen Fällen können Sie die Freisprechanlage selbstverständlich ohne Probleme zurück geben. " analog sehe ich es hier , womöglich kann man mit orginal OP -COM und der neuesten Software hier abhilfe schaffen und die Sprachsteuerung freischalten - erst das neueste Update unterstützt auch den Zafira Tourer, allerdings gibt s bei den neueren Modellen auch Dinge die sich einfach nicht programmieren lassen .
Es gibt bei opel 2 verschiedene Kabelbäume die verbaut werden , erkennen kann man es am Diagnosestecker , bei einem ist die Bordmikro vorbereitung dabei - beim andenen nicht .
Nachrüstung Freisprechanlage - hier wird es genauer erläutert
Nein es gut mir nur um die Aktivierung der Sprachsteuerung für das "DVD900" was ja
vorher ein DVD600 war. Weil hier immer die Frage offen war:
Braucht man ein zusätzliches Micro?" Wenn man sich meinen angegeben Link durchliest wird man feststellen man braucht kein 2-tes Micro sondern den VCI Code.
Soweit ich das jetzt verstehe.
Grüße irgendwie
Grüße irgendwie
Irgendwie kann ich die These mit den 2. Mikrophone auch nicht glauben, da dass Navi 600 ja bereits eine (kastrierte) Sprachsteuerung besitzt.
Kastriert? Mein 600er hat nichtmal die, also vollkommen taub ... :D
Also ich kann mein Telefon mit dem 600er per Spracheingabe steuern. Wahrscheinlich fehlt Dir einfach das Telefonmodul, richtig?
Jepp! Keine FSE, garnix ... ;)
Und das ist es wohl auch! Habe den Stick mal am PC angeschlossen. Lesen ging fehlerfrei, aber schon ein formatieren ging nicht mehr. Schade. :-)
Danke dir für den Tipp!
Leider schlechte Nachrichten aus einem anderen Forum :
Moin, AN ALLE!!!
also die Sprachfunktion im Navimodus wird beim 600er Radio NIE funktionieren. Es ist eine andere Hardware verbaut. Es gibt kein Microphonanschluss auf der Platine im 600er Radio.
Für alle Technikfreaks unter euch: Bei beiden Radios gehen die Leitungen vom Micro in die UHP hinein, und beim 900er Radio von der UHP weiter ins Radio hinein (Pin 6 und 16). Da aber das 600er eine andere Hardware in dem Bereich hat,(kein Umsetzer), bringt es nichts, da Leitungen nachzuziehen. Habs hinter mir und hat nichts gebracht, ist auch keine Programmierungssache. Das habe ich auch schon raus gefunden.
ALSO BITTE KEINE UNNÖTIGEN THREADS AUFMACHEN! SOMIT KEINE SPRACHERKENNUNG IM NAVIMODUS DES 600ER RADIO!!!!
http://www.zafira-forum.de/showthread.php?...
Mich würde ein Foto des Unterschied s auf der Platine interessieren .. leider benötigt man dazu Navi 600 und Navi 900 . Mit einem recht einfachen einziehen eines 2. Mikrofons und Anschluss auf Pin 6 und 16 scheint es jedenfalls leider nicht getan zu sein .
Moin, AN ALLE!!!
Kann ich mir ehrlich gesagt nicht vorstellen, da ja erwiesener Maßen die Spracherkennung auch bei einem Navi 600 in Verbindung mit dem Telefonmodul funktioniert.
Die Sprachsteuerung des Telefonmoduls hat NICHTS mit der Sprachsteuerung des Navis zu tun. Das sind zwei komplett verschiedene Baustellen.
Ich habe auch das Navi 600 und finde den beitrag sehr interresant, nun habe ich 2 fragen. Ich habe mir die 2 dateien gedownloadet inklusive anleitung in der als 2. Punkt steh das man die ISO datei auf einen leeren CD Rohling brennen muss. Muss ich die ISO selbst erstellen aus den dateien oder sollte die schon in dem herunter geladenen Ordner enthalten sein? wie muss ich mir den Routenplaner vom Navi 900 vorstellen? kann man da mehrere zwischenziele eingügen oder wie funktioniert er? hat jmd auch evtl ein Bild das er hochladen könnte?
danke im vorraus
