ForumA8 D2
  4. Audi
  5. A8
  6. A8 D2
  7. Kombiinstrument Pinbelegung
Audi A8 D2/4D
Themenstarteram 7. Mai 2021 um 22:00
Hallo Leute!
Ich habe mir einen A8 D2 Tacho gekauft und würde den gerne an den PC anschließen mit einem Arduino, nur leider finde ich nirgends die Pinbelegung von dem Tacho welcher Pin was ansteuert. Hat da jemand ahnung davon wenn ja bitte meldet euch :D
Mfg
Nico
2 Antworten
Hab hier was für VFL Fahrzeuge (bis ca. BJ 98), das ich mal im Netz gefunden hatte. Keine Garantie auf Richtigkeit, hab selbst nur den Bremsverschleißpin angefasst.
Pre Facelift Instrument Cluster Pin Assignment
Multi-pin connector -A- (26-pin - yellow) assignments
1 - Fuel level sensor signal
2 - Fuel level sensor Ground (GND)
3 - Door contact, driver's door
4 - Ignition key, terminal 86s
5 - Brake fluid level and hydraulic fluid level
6 - Seat belt switch
7 - Washer fluid level
8 - Parking light, right
9 - On board computer reset, left
10 - Board computer reset, right
11 - Board computer reset
12 - Temperature sensor Ground (GND)
13 - Fuel volume sensor (reserve)
14 - Outside air temperature sensor/ AC system
15 - Open
16 - Audio signal "On"
17 - Engine coolant temperature sensor signal
18 - Engine coolant level warning
19 - Brake light
20 - Backup light/low beam headlight
21 - Parking light, left
22 - Coolant fan third speed
23 - Engine oil temperature Ground (GND)
24 - Engine oil temperature
25 - Outside temperature sensor Ground (GND)
26 - A/C compressor "Off"
Multi-pin connector -B- (26-pin - red) assignments
1 - Trunk lid
2 - Door contact for driver's door
3 - Door contact, left rear
4 - Door contact, right rear
5 - Fuel level (for OBD II)
6 - Open
7 - Oil pressure 1.2 bar
8 - Open
9 - Transmission range indicator
10 - Open
11 - Auxiliary heater (remote control input)
12 - Hydraulic pressure
13 - Time signal as of ABS system 5.3 (open with ABS system 5.0)
14 - Open
15 - Open
16 - Open
17 - Summer/Winter
18 - RPM signal
19 - Fuel consumption signal
20 - Auxiliary heater
21 - Open
22 - Speedometer vehicle speed signal (output 2)
23 - Speedometer vehicle speed signal (output 1)
24 - Speedometer vehicle speed signal sensor signal (input)
25 - Brake pad wear indicator signal
26 - K-wire
Multi-pin connector -C- (26-pin - green) assignments
1 - Open
2 - Open
3 - Open
4 - Open
5 - Open
6 - Airbag
7 - ABS
8 - Door lock (output)
9 - Turn signal, left
10 - Open
11 - Open
12 - Open
13 - Open
14 - Open
15 - ASR
16 - OBD II
17 - Trailer turn signal lights
18 - Open
19 - High beam
20 - Parking brake warning light
21 - Generator (GEN) warning light
22 - Turn signal, right
23 - Open
24 - Open
25 - Airbag (active)
26 - ABS (Sila)
Multi-pin connector -D- (6-pin - white) assignments for voltage supply
1 - Terminal 30
2 - Terminal 31
3 - Illumination (3 W)
4 - Illumination for console (40 W)
5 - Terminal 58
6 - Terminal 15
Multi-pin connector -E- (4-pin) assignments for transmitter clock
1 - Transmitter clock signal
2 - Transmitter clock 5V
3 - Open
4 - Radio/Navigation clock ground
Am Stecker 26 Pin Rot
sind die Pins
14,15 und 16 für ENA, CLK , Data
für die Anzeige Im FIS für Radio Info und Navi Info.
Ist ein serielles 3 Leiter Protokoll.
Damit kann relativ einfach im FIS Graphik oder Schrift angezeigt werden.
  4. Audi
  5. A8
  6. A8 D2
