Adaptive Cruise Control nachrüsten
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten 🙂 War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch 🙂 Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software 🙂 It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 Antworten
ich würde einfach nur die richtige Software aufspielen (lassen). Die Hardware ist ja bei beiden die gleiche. Dann blöeibt dir die Geschichte mit der Wegfahrsperre wenigstens erspart...
Hallo Leute,
ich habe noch mal ein Problem, was nicht zu hundert Prozent dem Thema entspricht, aber doch auch etwas damit zu tun hat.
Und zwar wollte ein Kumpel gestern den GRA nachrüsten. Einbau hat soweit alles geklappt, die Batterie war währenddessen abgeklemmt. Nachdem nun alles wieder fertig zusammengebaut war hat er die Batterie angeklemmt und plötzlich sagte das MMI, dass die Batterie leer ist! Im FIS hat nun die Vorglühlampe geblinkt.
Dann wurde das neue Lenksäulensteuergerät erstmal auf GRA codiert. Bis dahin hat auch noch alles soweit funktioniert.
Allerdings ist im Motorsteuergerät folgender Fehler seit dem Umbau hinterlegt:
Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
Component: R4 2,0L EDC H21 5073
Revision: 25H21---
Coding: 1219401A241403080000
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM20TDI03L906022NP A02002
ROD: EV_ECM20TDI03L906022NP.rod
1 Fault Found:
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 55102 km
Date: 2014.08.07
Time: 16:35:28
Readiness: 0 0 0 0 0
Beim checken der Codierung wurde festgestellt, dass dort total unplausible Werte hinterlegt sind (bspw. ist jetzt DSG statt Schaltgetriebe hinterlegt, beim Hersteller steht Skoda, GRA und ACC waren beide drin usw...) Ändern lässt sich die Codierung jedoch nicht, da es keine anderen Werte annimmt! (Coding rejected; Fehler 22)
Was kann das sein?
LG und Vielen Dank vorab
scorpy-john
Edit: Es handelt sich um einen 2.0 TDI Avant 125 kW Vor Facelift
man kannn nicht immer den Vorgaben von VCDS trauen; das nur vorweg!
Hast du deine alte codierung vom MSG nicht mehr?
wenn ja diese mal komplett ohne die GRA einspielen
die andere Sache ist; nutzt du eine "legale" VCDS version?
wenn ja diese mal komplett ohne die GRA einspielendie andere Sache ist; nutzt du eine "legale" VCDS version?
Die alte Codierung vom MSG ist nicht vorhanden. Allerdings wurde auch im MSG nichts durch das VCDS geändert. Kann durch abklemmen der Batterie denn eine Änderung im MSG auftreten? Mich wundert es halt vor allem, dass der Ladezustand der Batterie so drastisch gesunken sein soll.
Es ist nicht mein Auto und ich war auch nicht vor Ort, sondern habe lediglich alle Informationen über Telefon und den Log per EMail bisher...
Und zu der anderen Sache... Ich würde jetzt einfach mal behaupten, dass es keine legale Version ist.
dann kann es schon mal daran liegen das er nicht codieren kann
und nein durch Bat-abklemmen ändert sich keine Codierung
der oder die die es umgebaut haben, sollen erstmal alles wieder zurücksetzen (sofern sie was codiert haben)
paar meter fahren dann weiter sehen; und ggf mal eine legale Version für ein paar € mehr besorgen!
durch die billigteile kann auch schon ma sich die codierung weghängen oder verändern ohne das man gewollt was im stg codieren wollte
Mit aktueller software konnte jetzt auch im MSG der GRA codiert werden. Jetzt funktioniert alles bestens.
Mit diesen sche** billig Nachbauten wird einfach immer wieder am falschen ende gespart...
Frage zu Kalibrierung mit VCDS: Ist Schraube 1 unten links und Schraube 2 oben rechts?
Ist die obere Schraube nur für vertikale Anpassung und untere nur für horizontale?
Angabe 0.75 Rechts meint rechtsstehend um 3/4-Drehung?
Besten Dank
von hinten gesehen ist die Drehung zu betrachten- hat mich auch am Anfang ein paar "runden" gekostet
Ah, danke dir!!!
Ich dachte schon, wie denn nach der Kalibrierung der Messwertblock eine grössere Grad-Abweichung als zu Beginn haben kann.
du musst eh fahren bevor er die werte im MWB ändert und erfasst
da ich mein Auto heute bei Audi zur Kalibrierung habe habe ich hier auch direkt eine Frage dazu.
Der Techniker hat mich soeben angerufen und gemeint, dass er alles kalibriert hat und er auch die Messung angenommen hat, im Messwertblock aber nach wie vor ein Winkel von 1,39° steht. Dieser Winkel stand auch schon vor Beginn der Kalibrierung dort. Ich habe ihm dann gesagt, dass er mit aktiviertem ACC fahren muss, bevor der neue Winkel in die Control unit geschrieben wird, ist das richtig?
Er meinte dann halt, dass er das nicht machen kann, da ja das ACC aufgrund des verstellten Sensors nicht funktioniere.
Er hätte dann danach die Stellschrauben in alle möglichen Richtungen verdreht und auch dann ändere sich der Messwertblock nicht. Die Kalibrierung hat er dann danach wieder erneut durchgeführt.
Wo liegt hier das Problem? Kann mir jemand weiterhelfen??
Ich muss das Auto heute abholen dort. Die Wollen jetzt schon 400 Euro von mir, ohne dass es funktioniert. Dabei sagt man mir vorher "Ja, wir können Ihnen das kalibrieren". Der Techniker meinte eben allerdings, er habe das selbst noch nicht gemacht...
Edit: Hat sich erledigt. Er hat sich doch nochmal breit schlagen lassen ne Runde zu fahren und nun gehts 🙄
Wenn man die Kalibrierung durchführt, wird der Dejustagewinkel auf 0.00 Grad gesetzt. Funktioniert nur manchmal nicht gleich. Hier hilft es den Radarsensor mal für 10 Minuten abzustecken - stromlos zu machen. Danach mit aktivierten ACC fahren. Dann wird der neue Winkel im Messwerteblock eingetragen.
Wenn sich das ACC gar nicht justieren lässt, hatten wir auch schon den Fall das der Stößfänger (Metall Teil hinter Sto?stange) leicht verbogen war. Optisch war das nicht gleich festzustellen. Hoffe es hilft dir weiter
