Adaptive Cruise Control nachrüsten
ich hab den Tempomat eingebaut und könnt den " adaptive cruise control Sensor" günstig ranbekommen. Die Frage ist nur, in wie fern ich damit das System nachrüsten kann. Was fehlt noch. Wo würde ich preislich landen?
Ich habe kein Navi, also kein MMI.
... Danke
Moin, dann habe ich es endlich geschafft ACC für meinen Audi A4 8k 2008 2.0 TDI CAGA mit JJG Getriebe nachzurüsten :) War ein langer Kampf wegen anderer Getriebeübersetzung als der Audi A4 8k der ACC hat (ab 11.2008 glaube ich…). Unten gibt die Anleitung ohne Getriebeaustausch :) Aber auf Englisch weil Deutsch nicht meine Muttersprache ist und vielleicht haben auch andere Interesse daran…
As mentioned above, I wanted to retrofit ACC. After doing everything according to instructions in this thread etc. and flashing the ECU with new software, the gear indicator in the instrument panel disappeared and ACC was disabled in 5th and 6th gear (where you would really need it). After a lot of research, I found out that the gear ratio was changed before the version with ACC was released. KXP is the number of the new manual gearbox with longer ratio I believe… In some Italian forums, they have managed to retrofit this, but only after changing the gear box. I have finally managed to do it with only changing the ECU software :) It took A LOT of reverse engineering and trial and error editing the flash file.
My original configuration:
Audi A4 Avant 8k 2008 2.0 TDI CAGA 143PS and JJG manual gearbox – First time registered 01.06.2008.
ECU HW: 03L 906 022B SW: 03L906022B version 9970
(No responsibility taken if this does not work on your car, and if you really want to be 100% sure not to get IMMO problems or similar, you may consider to extract the ECU and backup the complete SW with internal flash and EEPROM in bootmode.) However I did it according to below without any issues… NB! Important to ensure stabile voltage during flashing! E.g. connected to power source or (not optimal) good status of battery….
Step by step guide:
After having done everything according to the standard ACC retrofit guides, do the following to adapt gear ratio.
1. Read out the Internal flash data of your ECU SW xxxB, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
Flash the ECU to a SW which supports ACC. SW xxxB does not support it. I used MJ version, and flashed with VAG CAN Professional. Flash files can be downloaded via e.g. erWin in the frf format.
New SW: 03L 906 022MJ version 9335
2. Read out the Internal flash data of your ECU SW xxxMJ, 2048 kb. You can e.g. use Galletto FGtech v54 via OBD. Bootmode was not required for me.
3. Using a hex editor (or even better tools such as WinOLS) update the area which contains the gear ratio for the instrument panel.
In my flash it was found at address:
a. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed:
My old B SW (new values for your MJ file):
Decimal, 16 bit, unsigned:
2240 2560 2624 3264 3328 4224 4480 6144 7040 10240 11520 19200
Hex, 16 bit:
08C0 0A00 0A40 0CC0 0D00 1080 1180 1800 1B80 2800 2D00 4B00
My new MJ SW (values to be replaced with values above from B SW):
2061 2432 2534 2982 3136 3878 4147 5478 6016 8934 10227 16218
Hex, 16 bit:
080D 0980 09E6 0BA6 0C40 0F26 1033 1566 1780 22E6 27F3 3F5A
b. 1A0ED2 to 1A0EE8 – Axis transmission ratio between engine speed and vehicle speed,2:
2176 2611 2662 3264 3328 4096 4224 6144 6272 10240 10880 19200
Hex, 16 bit:
0880 0A33 0A66 0CC0 0D00 1000 1080 1800 1880 2800 2A80 4B00
2035 2458 2509 3021 3098 3942 4083 5606 5888 9267 9907 16922
Hex, 16 bit:
07F3 099A 09CD 0BCD 0C1A 0F66 0FF3 15E6 1700 2433 26B3 421A
If you have the same values in your B and MJ read flash files all should be good! I have identified this using various flash files read for SW such as B (not ACC suppport), MJ (ACC support), JM (ACC support), and changing MJ vs B differences gradually.
c. 1F9054 to 1F9078 – Min, max and change of gear ratio between engine speed and vehicle speed:
If you investigate DAMOS files it seems to be second area which also represent gear ratio, however it is not required to get the gear indicator working in the instrument panel.
“Parameter für maximales Übersetzungsverhältnis Gang 1 (1x1)”
„Parameter für minimales Übersetzungsverhältnis Gang 1 (1x1)“
„Parameter für Übersetzungsverhältnis vom 1. in den 2. Gang (1x1) „
„Parameter für maximales Übersetzungsverhältnis Gang 2 (1x1) „
1260 0 1260 2000 1260 2000 2800 2000 2800 3800 2800 3800 4700 3800 4700 32767 4700 1000 1000
Hex, 16 bit:
04EC 0000 04EC 07D0 04EC 07D0 0AF0 07D0 0AF0 0ED8 0AF0 0ED8 125C 0ED8 125C 7FFF 125C 03E8 03E8
1200 0 1200 2000 1200 2000 3000 2000 3000 3900 3000 3900 4900 3900 4900 30000 4900 1000 1000
Hex, 16 bit:
04B0 0000 04B0 07D0 04B0 07D0 0BB8 07D0 0BB8 0F3C 0BB8 0F3C 1324 0F3C 1324 7530 1324 03E8 03E8
d. Save/export the bin-file.
5. Flash the file to the ECU using e.g. Galletto FGtech v54 via OBD. NB! The new checksum needs to be correctly updated using your editor (e.g. WinOls” or flashing software (e.g. Galletto).
1798 Antworten
hier der rest der codierung :
Adresse 01: Motorelektronik (J623-CCWA) Labeldatei: 059-907-401-CAP.clb
Teilenummer SW: 8R0 907 401 J HW: 8K1 907 401 A
Bauteil: 3.0TDI EDC17 H14 0008
Revision: 15H14---
Codierung: 011C002C240F0220
Betriebsnr.: WSC 12345 123 12345
ASAM Datensatz: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 39729BA9B829ACD0262
1 Fehler gefunden:
4330 - Funktionseinschr‰nkung durch empfangenen Fehlerwert
U1113 00 [039] - -
unbest‰tigt - gepr¸ft seit letzter Lˆschung
Freeze Frame:
Fehlerstatus: 00000001
Fehlerpriorit‰t: 2
Fehlerh‰ufigkeit: 1
Kilometerstand: 8424 km
Datum: 2013.05.02
Zeit: 16:50:27
Readiness: 0 0 0 0 1
Codierung wurde NACH dem Scan geändert :
Adresse 13: Distanzregelung (J428) Labeldatei: DRV\8K0-907-561.clb
Teilenummer SW: 8K0 907 561 HW: 8K0 907 561
Bauteil: ACC2 H09 0080
Seriennummer: 00000000000000
Codierung: 00C7D9
VCID: EFE6E5F13EEDB260486
Gateway is' ok. Haste mal den kompletten Scan?
yes :
(wie gesagt ACC war da noch nicht richtig codiert ; steht jetzt auf 0079B9 )
ich vermute das AHK Stg (ist von Jäger- nachgerüstet- ebenfalls heute)
zudem kam Fernlichtassi rein (war in dem scan noch codiert- der spiegel war aber defekt am gehäuse wurde daher abgeklemmt)
homelink wurde auch nachgerüstet- Kunde hat aber das falsch Stg (taster) mit gebracht ;)
daher auch noch in der codierung drin
im Stg 01 wurde NACH dem scan auch noch die AHK gesetzt (ist hier nicht mit drin)
trotzdem bleibt der Fehler im MSG - Empfangener Fehlerwert und nach dem Zündungswechsel 10 Fehler im ACC Stg (mit sporadischer Kommunikations Problemen Lenkwinkl / Tacho / MSG usw
01-Motorelektronik -- Status: Fehler 0010
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
06-Sitzverst. Beifah. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: Fehler 0010
09-Zentralelektrik -- Status: Fehler 0010
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: Fehler 0010
14-Radd‰mpfung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: Fehler 0010
1B-Aktive Lenkung -- Status: i.O. 0000
20-Fernlichtassistent -- Status: nicht erreichbar 1100
22-Allrad -- Status: i.O. 0000
26-Elektr. Dachbet. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
42-T¸relektr. Fahrer -- Status: i.O. 0000
46-Komfortsystem -- Status: Fehler 0010
47-Soundsystem -- Status: i.O. 0000
52-T¸relektr. Beifahr. -- Status: i.O. 0000
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
56-Radio -- Status: i.O. 0000
57-TV Tuner -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
62-T¸relektr. hi. li. -- Status: i.O. 0000
69-Anh‰nger -- Status: i.O. 0000
6C-R¸ckfahrkamera -- Status: Fehler 0010
72-T¸relektr. hi. re. -- Status: i.O. 0000
Revision: 15H14---
1 Fehler gefunden:
U1113 00 [039] - -
Freeze Frame:
Fehlerpriorit‰t: 2
Fehlerh‰ufigkeit: 1
Datum: 2013.05.02
Zeit: 16:50:27
Adresse 02: Getriebe (J217) Labeldatei: DRV\0B5-927-156.clb
Teilenummer SW: 8K1 927 156 H HW: 0B5 927 156 F
Bauteil: 0B5 30 TDIRdW H10 0010
Revision: --H10--- Seriennummer: 0000000401
Codierung: 000001
Betriebsnr.: WSC 02145 785 00200
ASAM Datensatz: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 3A7084A5BD2FA7C82F8
Kein(e) Fehlercode(s) gefunden.
Adresse 03: Bremsenelektronik (J104) Labeldatei: DRV\8K0-907-379.clb
Teilenummer SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Bauteil: ESP8 quattro H04 0060
Revision: -------- Seriennummer: --------------
Codierung: 1CED0A
VCID: 8200BC451D7FAF08B78
Adresse 05: Zugangs-/Startber. (J393) Labeldatei: DRV\8K0-907-064-05.clb
Teilenummer SW: 8K0 907 064 CQ HW: 8K0 907 064 CQ
Bauteil: BCM2 2.0 H05 0435
Revision: 00002001
Codierung: 05030F
Betriebsnr.: WSC 02399 823 56573
VCID: 8102B3491879B410AE2
Subsystem 1 - Teilenummer SW: 8K0 905 852 D HW: 8K0 905 852 D
Bauteil: J764 ELV MLB H37 0042
Adresse 06: Sitzverst. Beifah. (J521) Labeldatei: 8T0-959-760.clb
Teilenummer SW: 8T0 959 760 C HW: 8T0 959 760 C
Bauteil: MEM-BFS H10 0074
Revision: AA000000 Seriennummer: 00000006178932
Codierung: 08017025002400001000
Betriebsnr.: WSC 02391 823 56573
VCID: 438EF941C2E5E6007CE
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei: Umleit. fehlgeschl.!
Teilenummer SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Bauteil: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Seriennummer: 01230520110757
Codierung: 361F0008
VCID: 8004B64D1373BD18A1C
6 Fehlercodes gefunden:
01207 - Steuerger‰t f¸r Zusatzheizung (J364)
004 - kein Signal/Kommunikation
Freeze Frame:
Fehlerstatus: 01100100
Fehlerpriorit‰t: 6
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:27
00713 - Stellmotor f¸r Mittenausstrˆmer links (V110)
008 - unplausibles Signal
Freeze Frame:
Fehlerstatus: 01101000
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:28
Freeze Frame:
Spannung: 11.80 V
Temperatur: 26.0?C
Temperatur: 24.0?C
Anzahl: 12302
Anzahl: 12302
Bin‰rwert: 00000100
Bin‰rwert: 00000000
Bin‰rwert: 00001001
01274 - Stellmotor f¸r Staudruckklappe (V71)
Freeze Frame:
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:28
Freeze Frame:
Spannung: 11.80 V
Temperatur: 26.0?C
Temperatur: 24.0?C
Anzahl: 10000
Anzahl: 10000
Bin‰rwert: 00000100
Bin‰rwert: 00000000
Bin‰rwert: 00001011
00716 - Stellmotor f¸r Umluftklappe (V113)
Freeze Frame:
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:28
Freeze Frame:
Spannung: 11.80 V
Temperatur: 26.0?C
Temperatur: 24.0?C
Anzahl: 11628
Anzahl: 11628
Bin‰rwert: 00000100
Bin‰rwert: 00000000
Bin‰rwert: 00001001
01809 - Stellmotor f¸r Temperaturklappe links (V158)
Freeze Frame:
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:28
Freeze Frame:
Spannung: 11.70 V
Temperatur: 26.0?C
Temperatur: 24.0?C
Anzahl: 10006
Anzahl: 10006
Bin‰rwert: 00000100
Bin‰rwert: 00000000
Bin‰rwert: 00000111
00710 - Stellmotor f¸r Defrostklappe (V107)
Freeze Frame:
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:28
Freeze Frame:
Spannung: 11.70 V
Temperatur: 26.0?C
Temperatur: 24.0?C
Anzahl: 10090
Anzahl: 10091
Bin‰rwert: 00000100
Bin‰rwert: 00000000
Bin‰rwert: 00000011
Adresse 09: Zentralelektrik (J519) Labeldatei: DRV\8K0-907-063.clb
Teilenummer SW: 8K0 907 063 P HW: 8K0 907 063 P
Bauteil: BCM1 1.0 H30 0392
Revision: 10030001 Seriennummer: 00000001075990
Codierung: 260050114074AF313E09000300005D5D4F9CE3C802010161000003
VCID: 3C7C82BDBF1B99F83D4
Subsystem 1 - Teilenummer SW: 8F1 955 119 HW: 8K1 955 119 Labeldatei: DRV\1KX-955-119.CLB
Bauteil: WWS 200511 H07 0021
Codierung: 00FD11
Subsystem 2 - Teilenummer SW: 8K0 955 559 HW: 8K0 955 559 Labeldatei: DRV\8K0-955-559.CLB
Bauteil: RLS H04 0003
Codierung: 02562A
Subsystem 3 - Teilenummer SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Bauteil: E1 - LDS H03 0031
3 Fehlercodes gefunden:
01330 - Zentralsteuerger‰t f¸r Komfortsystem (J393)
013 - bitte Fehlerspeicher auslesen
Freeze Frame:
Fehlerstatus: 01101101
Fehlerpriorit‰t: 6
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:00
02258 - Sendeeinheit Garagentorˆffner
Freeze Frame:
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:00
03395 - Steuerger‰t f¸r Fernlichtassistent
Freeze Frame:
Fehlerpriorit‰t: 6
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:00
Adresse 10: Einparkhilfe 2 (J446) Labeldatei: DRV\8K0-919-475.clb
Teilenummer SW: 8K0 919 475 AA HW: 8P0 919 475 N
Bauteil: PARKHILFE 8K H01 0080
Revision: 11001001 Seriennummer: 12501113400057
Codierung: 300101
VCID: 78F45EADCBA375D819C
Codierung: 00C7D9
1 Fehler gefunden:
01044 - Steuerger‰t falsch codiert
000 - -
Freeze Frame:
Fehlerstatus: 01100000
Fehlerpriorit‰t: 2
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:26
Freeze Frame:
Temperatur: 39.0?C
Spannung: 11.65 V
Bin‰rwert: 01000
Hex Wert: 0x044B
Hex Wert: 0x0002
Geschwindigkeit: -3.6 km/h
Querbeschleunigung: 0.00 m/s^2
Adresse 14: Radd‰mpfung (J250) Labeldatei: DRV\8R0-907-364.clb
Teilenummer SW: 8R0 907 364 B HW: 8K0 907 364
Bauteil: DAEMPFUNGS-SG H09 0053
Revision: 00000000 Seriennummer: 12051101440001
Codierung: 050181
VCID: 39729BA9B029ACD0262
Adresse 15: Airbag (J234) Labeldatei: 8F0-959-655.clb
Teilenummer SW: 8F0 959 655 C HW: 8F0 959 655 C
Bauteil: AirbagVW-AU10 H11 0430
Seriennummer: 003JND706C1+
Codierung: 30393635353130303030554A304C38463053
ASAM Datensatz: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 38749EAD8323B5D8D9C
Crashsensor f¸r Seitenairbag Fahrerseite:
Seriennummer: 6334MSME5F322F1FV
Crashsensor f¸r Seitenairbag Beifahrerseite:
Seriennummer: 6344MSME5E223639I
Crashsensor f¸r Seitenairbag hinten Fahrerseite:
Seriennummer: 6352QSME321D0E60G
Crashsensor f¸r Seitenairbag hinten Beifahrerseite:
Seriennummer: 6362QSME3F1D4474T
Crashsensor f¸r Frontairbag Fahrerseite:
Seriennummer: 63732SME712E3A744
Crashsensor f¸r Frontairbag Beifahrerseite:
Seriennummer: 63832SME5A1E084CB
Adresse 16: Lenkradelektronik (J527) Labeldatei: DRV\8K0-953-568.clb
Teilenummer SW: 8K0 953 568 G HW: 8K0 953 568 G
Bauteil: Lenks.Modul H17 0014
Revision: -------- Seriennummer: 90372KEG000M2
Codierung: 00003E
VCID: 3E7888B5A9078BE8130
Bauteil: E221 - MFL H02 0010
Adresse 17: Schalttafeleinsatz (J285) Labeldatei: DRV\8T0-920-xxx-17.clb
Teilenummer SW: 8T0 920 931 M HW: 8T0 920 931 M
Bauteil: KOMBIINSTR. H42 0258
Revision: 00000000 Seriennummer: EHX52UR5C
Codierung: 0F0F1900B7000008000000
VCID: 4182F349D8F9F4106E2
Adresse 19: Diagnoseinterface (J533) Labeldatei: DRV\8T0-907-468.clb
Teilenummer SW: 8T0 907 468 AE HW: 8T0 907 468 L
Bauteil: GW-BEM 5CAN-M H10 0117
Revision: FC100058 Seriennummer: 5800F1142802E3
Codierung: 00C303
VCID: 840CBA5D076BA138854
Subsystem 1 - Teilenummer SW: 8K0 915 181 E HW: 8K0 915 181 E
Bauteil: J367-BDM H07 0170
1 Fehler gefunden:
Freeze Frame:
Fehlerpriorit‰t: 2
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:32
Freeze Frame:
Bin‰rwert: 10111
Spannung: 11.50 V
Anzahl: 6
Bin‰rwert: 10011
Zeit: 25.40 s
Adresse 1B: Aktive Lenkung (J792) Labeldatei: DRV\8K0-907-144.clb
Teilenummer SW: 8K0 907 144 E HW: 8K0 907 144 E
Bauteil: DYNAMIKLENK. H06 0580
Revision: 50001005 Seriennummer: --------------
Codierung: 0C0000
VCID: 3162A389685964909E2
Adresse 20: Fernlichtassistent
nicht erreichbar
Adresse 22: Allrad (J492) Labeldatei: 8K0-907-163.clb
Teilenummer SW: 8K0 907 163 A HW: 8K0 907 163 A
Bauteil: 4 Wheel Drive H12 0025
Seriennummer: 001305110001054
ASAM Datensatz: EV_AllWheelDiffeQSPCAN 003016
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2E58B8F571677B68830
Adresse 26: Elektr. Dachbet. (J256) Labeldatei: 8F0-959-255.clb
Teilenummer SW: 8F0 959 255 HW: 8F0 959 255
Bauteil: VSG-AUDI-B8 H11 0190
Codierung: 010000
ASAM Datensatz: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: F1E2E38920D9A4905E2
Adresse 36: Sitzverst. Fahr. (J136) Labeldatei: 8T0-959-760.clb
Bauteil: MEM-FS H10 0074
Revision: AA000000 Seriennummer: 00000006179014
Codierung: 08017125002400001000
Betriebsnr.: WSC 21008 123 18712
Adresse 3C: Spurwechsel Labeldatei: DRV\8K0-907-566.clb
Teilenummer SW: 8K0 907 566 F HW: 4L0 907 566 B
Bauteil: J0769_SWA_MasterH01 0020
Revision: 00H01000 Seriennummer: 6PZ 009 014-19
Codierung: 0000105
VCID: 3A7084A5752FA7C82F8
Teilenummer: 8K0 907 568 F
Bauteil: J0770_SWA_Slave_H01 0020
Adresse 42: T¸relektr. Fahrer (J386) Labeldatei: 8K0-959-793.clb
Teilenummer SW: 8T0 959 793 M HW: 8T0 959 793 D
Bauteil: TSG FA H08 1501
Codierung: 011C52725008330C03
VCID: 53AEC90132857680CCE
Adresse 46: Komfortsystem (J393) Labeldatei: DRV\8K0-907-064-46.clb
Revision: 00002001 Seriennummer: 0150714796
Codierung: 011E0EA000B940A18320033280000000
Subsystem 2 - Teilenummer: 1K0 951 605 C
Bauteil: LIN BACKUP HO H05 1501
1 Fehler gefunden:
03233 - Bedieneinheit f¸r Garagentorˆffnung (E284)
Freeze Frame:
Fehlerpriorit‰t: 2
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Datum: 2013.05.02
Zeit: 16:50:32
Adresse 47: Soundsystem (J525) Labeldatei: DRV\8T0-035-223-BOM.clb
Teilenummer SW: 8F0 035 223 D HW: 8F0 035 223 C
Bauteil: DSP Prem H10 0190
Revision: 00010001 Seriennummer: 34806000731101
VCID: 214253C938B9D4100E2
Adresse 52: T¸relektr. Beifahr. (J387) Labeldatei: 8K0-959-792.clb
Teilenummer SW: 8T0 959 792 M HW: 8T0 959 792 D
Bauteil: TSG BF H08 1501
Codierung: 011C52325608330C03
VCID: 52A0CC050D9F7F88C78
Adresse 53: Feststellbremse (J540) Labeldatei: DRV\8K0-907-801-V1.clb
Teilenummer SW: 8K0 907 801 H HW: 8K0 907 801 H
Bauteil: EPB Audi B8 H09 0100
Revision: 00000003 Seriennummer: 00000000948368
Betriebsnr.: WSC 00000 000 00000
VCID: 346CAA9D974B51B8F54
Adresse 55: Leuchtweitenreg. Labeldatei: DRV\8K0-907-357.clb
Teilenummer: 8K0 907 357 D
Bauteil: Dynamische LWR H02 0010
Revision: 00000001 Seriennummer:
Codierung: 0000003
VCID: 36689095413743A8CB0
Adresse 56: Radio (R) Labeldatei: DRV\4F0-035-0xx-56.clb
Teilenummer SW: 4G0 035 061 D HW: 4G0 035 061
Bauteil: Radio U DAB H52 0100
Revision: AB001007 Seriennummer: 470EV0B7518134
Codierung: 010103010000000101
VCID: 1E38683509C7EBE8330
Adresse 57: TV Tuner Labeldatei: Keine
Teilenummer SW: KTC Selene HW: KTC Selene
Bauteil:
Revision: 00000000 Seriennummer: 00000000000000
Betriebsnr.: WSC 21977 142 74100
VCID: 3E7888B569078BE8130
Adresse 5F: Informationselek. I (J794) Labeldatei: DRV\4E0-035-6xx-5F.clb
Teilenummer SW: 8T1 035 670 J HW: 8T1 035 670 E
Bauteil: H-BNT-EU H52 0174
Revision: -------- Seriennummer: 491E/0B7554428
Codierung: 010100030206EBFF75000F1E000000010000
Subsystem 1 - Teilenummer: 8R0 060 884 N
Bauteil: EUR 2011 1205
Subsystem 2 - Teilenummer SW: 8F0 919 604 HW: 8F0 919 604
Bauteil: DU7 High H43 0098
Subsystem 3 - Teilenummer SW: 8T0 919 609 G HW: 8T0 919 609 G
Bauteil: E0380 Bedient H08 0100
Subsystem 4 - Teilenummer: 8R0 060 961 A
Bauteil: CD-Database 2712
Adresse 62: T¸relektr. hi. li. (J388) Labeldatei: 8K0-959-795.clb
Teilenummer SW: 8T0 959 795 L HW: 8T0 959 795 C
Bauteil: TSG HL H07 1501
Codierung: 010C12324008370C03
VCID: 54ACCA1D378B71B8D54
Adresse 69: Anh‰nger (J345) Labeldatei: DRV\8K0-907-383.clb
Teilenummer SW: 8K0 907 383 A HW: 8K0 907 383 A
Bauteil: ConWys Trailer H06 0040
Revision: 1A002002 Seriennummer: 00000132829524
Codierung: 0100000000000000
Betriebsnr.: WSC 00007 223 57222
VCID: 3260AC856D5F5F88E78
Adresse 6C: R¸ckfahrkamera Labeldatei: DRV\4L0-910-441.clb
Teilenummer SW: 8F0 907 441 HW: 4L0 907 441 B
Bauteil: J772__Rearview 0040
Revision: --H05--- Seriennummer: 525PA8-J1XB0QP
Codierung: 1031009
VCID: E7D68DD1D61D6A20006
1 Fehler gefunden:
03006 - R¸ckfahrkamerasystem nicht kalibriert
000 - -
Freeze Frame:
Fehlerpriorit‰t: 2
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 232
Zeitangabe: 0
Adresse 72: T¸relektr. hi. re. (J389) Labeldatei: 8K0-959-794.clb
Bauteil: TSG HR H07 1501
Ende --------------------------------------------------------------------
es gab doch schon mal das Problem mit dem Jäger-AHK Steuergerät und ACC. Da ging ACC nicht nach der AHK-Nachrüstung. Ich vermute fast, dass das nicht ACC-tauglich ist. Schmeiß' mal die AHK komplett raus (Stg abklemmen, Codierung)
das war / ist auch meine Idee ; nur nach 10 Std. reinen Umbau mit RFK/AHK/TV/HomeLink und ACC sowie Cabrio Modul; war da am Ende keine Zeit mehr ;)
ich werde es aber im zweiten schritt noch mal testen;
das ergebnis der letzten Jaeger AHK mit ACC war auch negativ - was draus geworden ist bis heute weis ich nicht
danke dir schon mal für deine Hilfe
gruss Andy
ich glaub' da wurde auf -nicht AHK- codiert...
dann schreibt er "stg falsch codiert"
alle hier bekannten und gelisteten Codierungen habe ich durch; alle meine Scans auch; die codierungen vom FL Modell werden so oder so nicht übernommen
die AHK komplett aus der Codierung nehmen, auch im Gateway...
ohne abklemmen hatte ich das bereits versucht ; als nächstes werde ich sie dann abklemmen
Vollzug! Hat geklappt! Danke Scotty18 und Spürer! Wenn jetzt der Menüpunkt Kombiinstrument im Car Menü wieder funktionieren wuerde (nach Kombitausch), dann waers perfekt. Aber das später. Freu mich :). Andy wird sicher Näheres schreiben.
Kabelsatz nun heute auch endlich verlegt, nachdem der Radarsensor schon 14 Tage montiert ist. :D
Ich hoffe allerdings, dass mir die Spezialisten hier weiterhelfen können und mich nicht steinigen.
Als ich CAN-Bus Extended High und CAN-Bus Extended Low vom Radarsensor am Gateway (8T0907468 AA) anschießen wollte, ist mir aufgefallen, dass diese bereits belegt sind. Habe diese Liste genommen zum Nachschauen und informieren: 20-pin multi-pin connector
Pin 7 Extended data bus, CAN-Low - belegt
Pin 17 Extended data bus, CAN-High - belegt
:confused: :confused: :confused:
Kenn ein Belegung jetzt nicht aus dem Kopf aber das kann schon sein z.b. Wenn dein fernlichtassistent da angeschlossen ist. Die verschiedenen Bus Systeme teilen sich ja einzelne Steuergeräte und elektronische Komponenten. Isolier die zwei Kabel einfach ab und löte oder Wickel Da die acc Leitungen an. Wenns ein richtigen pins sind ;). Hab Gerad die stromlaufpläne nicht da...
Wo könnte ich zur Not noch hin hinterm Handschufach, ohne doppelt zu belegen?
Stromlaufplan habe ich vor mir liegen.
Pin 7/17 am GW ist richtig. Es gibt keinen CAN Verteiler für den Extended CAN wo du dich einfach raufklemmen kannst.
Dann muss ich morgen mal eine Runde löten.
Leider kein Bier, vielleicht erst wenn die Arbeit getan ist. :D
