A6 C7 20" Rims tuv checkup
Hi all, im not long in Austria and i have first hickup with police, so basicly i have bought car with wich i got 2 sets of tyres, one is for winter 19" and one for somer 20"....police stoped me yesterday and said that i have to remove my 20" tyres with rims becouse they are not in car papers, that i need to get them checked at TUV.... so i will do that but before i go, could someone confirm my config or i need something to change so i could go trought sucesfuly...
Rims spec are folowing:... Model:AF10 9x20
Typ :F820 9Jx20H2
ausfuhrung: 69B
Distanc rings are: Front H&R 2455668 Spurverbreiterung 5x112, 12 mm
: Back H&R 3655668 Spurverbreiterung 5x112, 18 mm
They were on car for 2,5 years and i went two times trought Ömtc pickel without problem, so dont know this specs will be ok for TUV or not, i have to invest in new tyres, but its 1k out the window if they cant go on this car anyway...pls help.
3 Antworten
You must search for the documents for those rims/tyres-combination. Then you cn see, if it is allowed and finally the check-organisation must confirm and correct yor papers in combination distance-plates. Therefor you need as well the documents.
Here is TuV certificate for distance rings https://www.h-r.com/bin/112XT0079.pdf
And this is tuv certifikate for Felge https://tuev-gutachten.tyrol-pneu.at/10%20AVUS/AF10%20=%20F820%20(SAT21)/9x20/AF10%209X20%205X112%20ET45%2066.6%20(T%C3%9CV%20Pfalz).pdf
What bothers me is that in certifikate for distance rings there is no mention on 9x20 only 255/35 8,5x20...pls if anyone with knowledge for this stuf can clear it for me, becouse when they are mounted on car they dont poke outside but look like in line with arch, there is abaut 3cm distance from tire to arch.
Maybe this will help you
[url=https://www.oesterreich.gv.at/.../Seite.061630.html ]https://www.oesterreich.gv.at/.../Seite.061630.html [/url]
