CD 400 spielt MP3-Songs vom USB-Stick nur in zufälliger Reihenfolge
Hallo! Ich bin nicht Posting hier so oft, aber wieder habe ich Problem mit meinem Radio Wenn ich USB-Stick anschließen, um meine CD 400 spielt Songs nur in Radom-Modus. Ich kann es im Menü zu ändern, aber keine Wirkung. Wenn ich mp3 Songs zu spielen von der CD ist es OK. Er spielt Songs in der Reihenfolge ausgehend von der ersten Ordner spielen alle Songs und dann ab zum nächsten Ordner zu spielen. Sie haben die samme Problem? Wie man es beheben? Vielleicht gibt es eine Art Software-Update in Opel-Service?
Sorry für meine mangelnde Deutschkenntnisse - ich google Übersetzer verwenden.
English: Hello! I'm not posting here so often but again I have issue with my radio When i connect usb stick to my CD 400 it plays songs only in radom mode. I can change it in menu, but no effect. When I play mp3 songs from CD it is OK. It plays songs in order starting from first folder playing all songs and then starting to play next folder. Do You have the samme issue? How to fix it? Maybe there is some kind of software update in Opel service?
Sorry for my lack of German language - I have to use google translator.
MfG /Regards - Mirek |
I guess the CD400 has the same behaviour like my DVD800. The songs will be played in the order which they are copied on the stick. Unfortuantely Windows and I think Linux also don't care about an alphabetical sorted copy process. They start somewhere and end somewhere. And this is what you hear when you plug in your usb-stick and play it.
Is it possible to create playlists with the CD400? This may solve this issue. Or you need a software that copy the songs in the right order. This was already discussed in the board and tools were mentioned, at least for the DVD800 ;-)
HTH!
Thanks!
Yes, it is possible to create play list and I already have that idea, but no time to do that.
I think so complain at Opel is needed, because it should be easy to fix firmware - I will try
Mfg / Regards - Mirek
