TT-Lounge:
Zentralverriegelung: Problem - Tankklappe und Heckklappe lassen sich nicht per Schalter entriegeln
Meine Sicht der Welt:
In 21 Stunden nach Österreich und zurück
Kommentare: 1 -
MB Dieselmaster:
Der Grund meiner Sucht oder gibt es was Schöneres?
Kommentare: 10 -
Dr Seltsam:
Heimfahrt mit Hindernissen
Kommentare: 3 -
videoblog: Gumball 3000 -> 2012 from NY to LA Teil 1
Reinigung der Xenonlinsen Bei den A5 Scheinwerfern!:
Nachrüstung Keyless Go im Audi A5 Coupe
Audi TT 8N
Audi TT 2001 Radio safe code *how to*
Hi!
I replaced the battery from my TT and now I have to input the safe code to the radio to get it working. The radio is an original audi part. My manual isnt "speaking english", so cannot use it. I have heard that I have to press some keys from the radio but dont know which. Thanks!
-Pete |
Hello Pete,
I try to answer, although my English is not the best:
-> Press the keys ""SCAN" and "RDS" at the same time, until "SAFE" turns into "1000"
-> There are four station-keys.
Press the first station-key as often as your first code number.
For example, your first code number is five, you press the first key five times.
Do the same with the second station-key and your second code number,
and so on.
-> At the end you press the keys "SCAN" and "RDS" at the same time again.
Be careful, if you fail several times, your code is closed and you have to go to the AUDI-dealer.
Best regards,
Norbert
1xYou have two attempts!
Thanks for the help! Got it working.
-Pete
