- Passat
- Passat B6
- ABS 3AA614109AG in Passat B6
I want to share with you the wonderful news. I managed to install pack abs from Passat B7 Passat B6 in.
For what it's done:
1 Buttons handbrake now works as a Passat B7.
2 Perhaps enable electronic differential lock XDS.
3 You can set a full-Park Assist 2.0 + OPS 360.
Here are a few photos how it works.
http://data.motor-talk.de/.../2c75fccs-960-3308177035041247224.jpg
http://data.motor-talk.de/.../dab5fccs-960-7761245703361303768.jpg
Later add video
Ok, to sum it up. You figured out, that it's possible with a simple type of coding - but you don't provide it. Ok, thank you.
123 Antworten
Add a couple of photos...
@ssaxak schrieb am 8. September 2014 um 18:34:14 Uhr:
I'll post a full scan tomorrow. You do not mind that it will be in Russian?
I would not like for some reason the show encoding ABS. A little later I will take until the end of the experiments, and reveal all the secrets.
I want to make a V2 of abs to abs V3. On blocks 3c0 discoverer bronken already shown the video.
Your photos could be interpreted as 'end of experiments', so now would be the time to share your secrets, wouldn't it? ;)
Anyway, congratulations to your success and thumbs up!
Who will finish pla 2.0 and the experiment will be closed
@ssaxak schrieb am 6. November 2014 um 13:00:20 Uhr:
... have you got any news for us? I'm still curios (and I guess I am not the only one) ...
not only you, any news guys?
PLA2 in passat B6 installed
Great work buddy ;) thumbs up
PLA ist APK 97 im B7 ABS.
Der Codierwert +512 steht afaik für ZF Gen 3 verbaut.
Welche anderen Werte codiert werden müssen, einfach mal Probieren.
Wenn ich mich Recht entsinne, ist der Wert 2048 beim B7 immer aktiv. Vllt den mal rausnehmen.
Wo issn Turbosladi der hier wieder alle als Lügner beschimpfen kann?
Ohne hintere seitliche Sensoren ?
@Master2k: +2048 steht für RKA
@habmichlieb12: ABS aus B7 läst sich auch ohne B7-ABS-Sensoren betreiben. Man kann auch die B6-ABS-Sensoren kodieren. Ob damit auch PLA2.0 geht, bin ich überfragt.
Weißt jemand wofür +1024 und +8192 steht?
Nein. 1024 ist RDK. So wie es im Label von vcdd beschrieben ist
8192 ist mir noch nicht untergekommen.
16384
32768
65536 sind acc wobei 32k nur bei DSG ist.
Im Anhand nur ne Tabelle über MEIN ABS ( Index AC) was ich so im Netz finden konnte...
PLA-2 +256 open 94 canal adaptation
Dann 94... aber +256 ist IMMER codiert, auch wenn KEIN PLA verbaut ist. (hab dazu die Auto-Scan zur Hand genommen)
Hat jemand eine idee woran es liegen kann das bei mir die codierung im epb 22157 nicht angenommen wird ?
3aa epb , 3aa abs ( nur elektrisch angesteckt) sogar b7 miko ist drin , also nehme ich mal an das alle voraussetzungen da sind
