double-p
Nordschleife, RCN und sonstiges "schnelles" rund um's Auto
18.06.2009 23:41    |    double-p_OPC double-p_OPC    |    Kommentare (7)    |   Stichworte: ,
Ferrari 312PB
Ferrari 312PB
Das hier haut mich einfach nur von den Socken.
Da setzt sich dieser Pierre Scerri hin, zeichnet 3 Jahre Konstruktionsplaene und baut dann
12 Jahre (!!!) an diesem "Modell".
There are few if any models in the world to rival the Ferrari 312PB built by Pierre Scerri of Avignon, France. This 1:3 scale marvel is the real thing in every sense, from its operating 12-cylinder engine to the exact scale operating Ferrari gauges which are calibrated precisely to indicate rpm, oil pressure, water temperature and oil temperature.
It took Pierre 15 years and more than 20,000 hours to build this car. He learned to make glass so he could make the exact pattern lens for the operating headlights. He learned to make rubber so he could mold his own tires. His computer mainframe design background with the French telecommunications system allowed him to duplicate the Ferrari electronics system in exact miniature. It also provided him with the understanding needed to make a 1/3 scale operating fuel injection system identical to that in the full-size Ferrari.
Perhaps the toughest aspect of the car was the gearbox, for which Ferrari supplied drawings. While Pierre had an understanding of the object to be built, he lacked the very expensive specialized equipment required to build high-tolerance gears and synchros. Colleti, the builder of the full-size car’s gearbox ended up building the model’s gearbox.
There is no sign of deviation from the real car in terms of replication. The spark plugs are miniatures, the radiators were hand-built to the exact same core design as the real ones. Even the water reservoir fill cap is a Fiat radiator cap made exactly the same way as the real one and pressure tested. The suspension is exact and the hydraulically controlled brakes from the brake pedal have quick-change brake pads just as on the real car.
If you were 1:3 scale, you would open the door of the car, get in, fasten your seat belt as on the full-size car, take you Ferrari key (engraved identically to the real key) and put it into the ignition.
You would flip the toggle switch for the fuel pumps, and with this you would hear the fuel-injection system come to life, powered by a real scale battery built by Pierre. A crew member would stick the hand-held scale starter into the rear transaxle housing and as the engine turned over you would flip the ignition toggle switch and the 12-cylinder engine would come to life with a sound you’d never forget.
This 12-cylinder engine just isn’t any 12-cylinder engine, it is a 1:3 scale Ferrari 12-cylinder engine with the same beautiful sound. It took Pierre six months of running the engine on his own dynamometer to tune the header pipes so they would give off the same sound value as he had recorded from the engine of the real car. Once Pierre had the engine bolted together for the first time, it started on the very first try and, since then, has logged more than fifty hours of running time with no failures or refusals to start (It’s probably more reliable than the real engine).
In short, this model car is so incredible that one has a very difficult time focusing on the fact that it is a model and not a full-size car. Pierre has begun work on a 1:3 scale Ferrari P4. We’ll keep you updated.
(Quelle: http://www.fineartmodels.com/ )
Technical data
Engine
Flat-12 cylinder
Displacement : 103 cc
Stroke x Bore : 24mm x 19mm
Horse power : 8 ch @ 10,500 RPM
Cooling : 2 lateral radiators for water and 1 central radiator for oil
2 camshafts per cylinder banks
24 valves
Injection
Dry sump
Clutch
Hydraulic actuator
Brakes
Steel discs
Hydraulic actuator
4 piston callipers with removable pads
Transmission
5-gear + reverse - Differential
Cooling : oil pump + radiators
Chassis
N° 0884 PS
25 CD 4 S Tubes - Aluminium riveted
Adjustable shock absorbers
Steering system
Rack and pinion
Dimensions
Lenght - 1250 mm
Width - 650 mm
Height - 308 mm
Wheel base - 740 mm
Weight - 60 Kg
Der helle Wahnsinn!
PS: den Blog fuer 3. Lauf RCN bin ich noch "schuldig", habe aber erst jetzt die letzten Videos bekommen und morgen
geht's schon zum 4. Lauf an die Nordschleife. Stay tuned, kommt naechste Woche ;)
Kommentare: 7
18.06.2009 23:54    |    124er-Power 124er-Power
Wahnsinn! Da arbeitet der 12 Jahre dran, echt heftig. Aber sehr gelungen :)
19.06.2009 07:20    |    meehster meehster
Absolut gelungen. Gefällt mir wohl :)
19.06.2009 13:58    |    XC70D5 XC70D5
Wenn man sonst nix zu tun hat...
..aber trotzdem beeindruckende Arbeit!
Da fahre ich doch lieber gleich zur Nordschleife :D
Vielleicht sieht man sich ja mal wieder!?
Martin
19.06.2009 14:16    |    double-p_OPC double-p_OPC
Jawohl.. noch Zusammenpacken und dann geht's los! :D
Bin dann so 18:30 rum im alten Fahrerlager zur TA. Schau mal vorbei Martin.
22.06.2009 12:56    |    XC70D5 XC70D5
Ich war da! Wo warst Du?
Martin
22.06.2009 14:23    |    double-p_OPC double-p_OPC
Wurde leider eher 19 Uhr.. und morgens ab halb zehn zum Auto putzen..
Nach dem Rennen allerdings kein Parc ferme. Seufz.. spaeter im Blog mehr.
22.06.2009 16:00    |    XC70D5 XC70D5
Habe ich gar nicht mitbekommen, aber bei dem Wetter auch keine wirkliche Überraschung...
Martin
Zuletzt gespeichert: nie
Design:
Größe:
Zum Seitenanfang
  • Ferrari in 1:3 - voll funktionsfaehig : double-p (Permalink) | (c) 2001-2012 MOTOR-TALK GmbH
