01.06.2009 13:39
-=TbMoD=-
Kommentare (0)
GM Fehlercode Liste Teil 2 Powertrain Codes bis P1399: (rest siehe Teil3)
P0030 HO2S Heater Control Circuit Bank 1 Sensor 1 P0031 HO2S Heater Circuit Low Voltage Bank 1 Sensor 1 P0032 HO2S Heater Circuit High Voltage Bank 1 Sensor 1 P0036 HO2S Heater Control Circuit Bank 1 Sensor 2 P0037 HO2S Heater Circuit Low Voltage Bank 1 Sensor 2 P0038 HO2S Heater Circuit High Voltage Bank 1 Sensor 2 P0050 HO2S Heater Circuit Bank 2 Sensor 1 P0051 HO2S Heater Circuit Low Voltage Bank 2 Sensor 1 P0052 HO2S Heater Circuit High Voltage Bank 2 Sensor 1 P0056 HO2S Heater Circuit Bank 2 Sensor 2 P0057 HO2S Heater Circuit Low Voltage Bank 2 Sensor 2 P0058 HO2S Heater Circuit High Voltage Bank 2 Sensor 2 P0100 MAF Sensor Ckt. Insufficient Activity P0101 Mass Air Flow (MAF) Sensor Performance P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency P0104 Mass Air Flow Circuit Intermittent P0105 MAP Sensor Circuit Insufficient Activity P0106 Manifold Absolute Pressure (MAP) System Performance P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage P0109 Manifold Absolute Pressure Circuit Intermittent P0110 Intake Air Temperature (IAT) Sensor Circuit P0111 Intake Air Temperature (IAT) Sensor Performance P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage P0114 Intake Air Temperature Circuit Intermittent P0115 Engine Coolant Temperature (ECT) Sensor Circuit P0116 Engine Coolant Temperature (ECT) Sensor Performance P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage P0119 Engine Coolant Temperature Circuit Intermittent P0120 TP System Performance P0121 TP Sensor Circuit Insufficient Activity P0122 Throttle Position (TP) Sensor Circuit Low Voltage P0123 Throttle Position (TP) Sensor Circuit High Voltage P0124 Throttle Position Sensor 1 Circuit Intermittent P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control P0126 Insufficient ECT for Stable Operation P0128 Coolant Thermostat P0130 HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1 P0132 HO2S Circuit High Voltage Bank 1 Sensor 1 P0133 HO2S Slow Response Bank 1 Sensor 1 P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1 P0135 HO2S Heater Performance Bank 1 Sensor 1 P0136 HO2S Circuit Bank 1 Sensor 2 P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2 P0138 HO2S Circuit High Voltage Bank 1 Sensor 2 P0139 HO2S Slow Response Bank 1 Sensor 2 P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2 P0141 HO2S Heater Performance Bank 1 Sensor 2 P0142 HO2S Circuit Bank 1 Sensor 3 P0143 HO2S Circuit Low Voltage Bank 1 Sensor 3 P0144 HO2S Circuit High Voltage Bank 1 Sensor 3 P0145 HO2S Circuit Bank 1 Sensor 2 Slow Response P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3 P0147 HO2S Heater Performance Bank 1 Sensor 3 P0150 HO2S Circuit Closed Loop (CL) Performance Bank 2 Sensor 1 P0150 HO2S Circuit Bank 2 Sensor 1 P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1 P0152 HO2S Circuit High Voltage Bank 2 Sensor 1 P0153 HO2S Slow Response Bank 2 Sensor 1 P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1 P0155 HO2S Heater Performance Bank 2 Sensor 1 P0156 HO2S Circuit Bank 2 Sensor 2 P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2 P0158 HO2S Circuit High Voltage Bank2 Sensor 2 P0159 HO2S Slow Response Bank 2 Sensor 2 P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2 P0161 HO2S Heater Performance Bank 2 Sensor 2 P0162 HO2S Circuit Bank 2 Sensor 3 P0163 HO2S Circuit Bank 2 Sensor 3 Low Voltage P0164 HO2S Circuit Bank 2 Sensor 3 High Voltage P0165 HO2S Circuit Bank 2 Sensor 3 Slow Response P0166 HO2S Circuit Bank 2 Sensor 3 No Activity Detected P0167 HO2S Heater Circuit Bank 2 Sensor 3 P0169 Fuel Composition Sensor P0170 Fuel Trim Bank 1 P0171 Fuel Trim System Lean Bank 1 P0172 Fuel Trim System Rich Bank 1 P0173 Fuel Trim Bank 2 P0174 Fuel Trim System Lean Bank 2 P0175 Fuel Trim System Rich Bank 2 P0176 Fuel Composition Sensor Circuit P0177 Fuel Composition Sensor Circuit Performance P0178 Fuel Composition Sensor Circuit Low Voltage P0179 Fuel Composition Sensor Circuit High Voltage P0180 Fuel Temperature Sensor 1 Circuit P0181 Fuel Temp. Sensor 1 Circuit Performance P0182 Fuel Temperature Sensor Circuit Low Voltage P0183 Fuel Temperature Sensor Circuit High Voltage P0184 Fuel Temperature Sensor 1 Circuit Intermittent P0185 Fuel Temperature Sensor 2 Circuit P0186 Fuel Temp. Sensor 2 Circuit Performance P0187 Fuel Temperature Sensor 2 Circuit Low Voltage P0188 Fuel Temperature Sensor 2 Circuit High Voltage P0189 Fuel Temperature Sensor 2 Circuit Intermittent P0190 Fuel Rail Pressure Sensor Circuit P0191 Fuel Rail Pressure Sensor Circuit Performance P0192 Fuel Rail Pressure Sensor Circuit Low Voltage P0193 Fuel Rail Pressure Sensor Circuit High Voltage P0194 Fuel Rail Pressure Sensor Circuit Intermittent P0195 Engine Oil Temperature Sensor P0196 Engine Oil Temperature Sensor Performance P0197 Engine Oil Temperature Sensor Low Voltage P0198 Engine Oil Temperature Sensor High Voltage P0199 Engine Oil Temperature Sensor Intermittent P0200 Injector Control Circuit P0201 Injector 1 Control Circuit P0202 Injector 2 Control Circuit P0203 Injector 3 Control Circuit P0204 Injector 4 Control Circuit P0205 Injector 5 Control Circuit P0206 Injector 6 Control Circuit P0207 Injector 7 Control Circuit P0208 Injector 8 Control Circuit P0209 Injector 9 Control Circuit P0210 Injector 10 Control Circuit P0211 Injector 11 Control Circuit P0212 Injector 12 Control Circuit P0213 Cold Start Injector 1 P0214 Cold Start Injector 2 P0215 Engine Shutoff Control Circuit P0216 Injection Timing Control Circuit P0217 Engine Overtemp Condition P0218 Transmission Fluid Overtemperature P0219 Engine Overspeed Condition P0220 APP Sensor 2 Circuit P0221 APP Sensor 2 Circuit Performance P0222 APP Sensor 2 Circuit Low Voltage P0223 APP Sensor 2 Circuit High Voltage P0224 Throttle Position Sensor 2 Intermittent P0225 APP Sensor 3 Circuit P0226 APP Sensor 3 Circuit Performance P0227 APP Sensor 3 Circuit Low Voltage P0228 APP Sensor 3 Circuit High Voltage P0229 Throttle Position Sensor 3 Intermittent P0230 Fuel Pump Relay Control Circuit P0231 Fuel Pump Feedback Circuit Low Voltage P0232 Fuel Pump Feedback Circuit High Voltage P0233 Fuel Pump Secondary Circuit Intermittent P0234 TC Engine Overboost Condition P0235 Turbocharger Boost Sensor 1 Circuit P0236 TC Boost System P0237 TC Boost Sensor Circuit Low Voltage P0238 TC Boost Sensor Circuit High Voltage P0239 Turbocharger Boost Sensor 2 Circuit P0240 Turbocharger Boost Sensor 2 Performance P0241 Turbocharger Boost Sensor 2 Circuit Low Voltage P0242 Turbocharger Boost Sensor 2 Circuit High Voltage P0243 Turbocharger Wastegate Solenoid 1 P0244 Turbocharger Wastegate Solenoid 1 Performance P0245 Turbocharger Wastegate Solenoid 1 Low Voltage P0246 Turbocharger Wastegate Solenoid 1 High Voltage P0247 Turbocharger Wastegate Solenoid 2 P0248 Turbocharger Wastegate Solenoid 2 Performance P0249 Turbocharger Wastegate Solenoid 2 Low Voltage P0250 Turbocharger Wastegate Solenoid 2 High Voltage P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector) P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector) P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector) P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector) P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector) P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector) P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector) P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector) P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector) P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector) P0261 Cylinder 1 Injector Circuit Low P0262 Cylinder 1 Injector Circuit High P0263 Cylinder 1 Contribution/Balance Fault P0264 Cylinder 2 Injector Circuit Low P0265 Cylinder 2 Injector Circuit High P0266 Cylinder 2 Contribution/Balance Fault P0267 Cylinder 3 Injector Circuit Low P0268 Cylinder 3 Injector Circuit High P0269 Cylinder 3 Contribution/Balance Fault P0270 Cylinder 4 Injector Circuit Low P0271 Cylinder 4 Injector Circuit High P0272 Cylinder 4 Contribution/Balance Fault P0273 Cylinder 5 Injector Circuit Low P0274 Cylinder 5 Injector Circuit High P0275 Cylinder 5 Contribution/Balance Fault P0276 Cylinder 6 Injector Circuit Low P0277 Cylinder 6 Injector Circuit High P0278 Cylinder 6 Contribution/Balance Fault P0279 Cylinder 7 Injector Circuit Low P0280 Cylinder 7 Injector Circuit High P0281 Cylinder 7 Contribution/Balance Fault P0282 Cylinder 8 Injector Circuit Low P0283 Cylinder 8 Injector Circuit High P0284 Cylinder 8 Contribution/Balance Fault P0285 Cylinder 9 Injector Circuit Low P0286 Cylinder 9 Injector Circuit High P0287 Cylinder 9 Contribution/Balance Fault P0288 Cylinder 10 Injector Circuit Low P0289 Cylinder 10 Injector Circuit High P0290 Cylinder 10 Contribution/Balance Fault P0291 Cylinder 11 Injector Circuit Low P0292 Cylinder 11 Injector Circuit High P0293 Cylinder 11 Contribution/Balance Fault P0294 Cylinder 12 Injector Circuit Low P0295 Cylinder 12 Injector Circuit High P0296 Cylinder 12 Contribution/Range Fault P0300 Engine Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0305 Cylinder 5 Misfire Detected P0306 Cylinder 6 Misfire Detected P0307 Cylinder 7 Misfire Detected P0308 Cylinder 8 Misfire Detected P0309 Cylinder 9 Misfire Detected P0311 Cylinder 11 Misfire Detected P0312 Cylinder 12 Misfire Detected P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance P0322 IC Module 4X Reference CKT No Frequency P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent P0325 PCM Knock Sensor Circuit P0326 Knock Sensor CKT Excessive Spark Retard P0327 Knock Sensor Circuit Low Voltage P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor) P0330 Knock Sensor (KS) Circuit Bank 2 P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2) P0332 Knock Sensor 2 Circuit Low Input (Bank 2) P0333 Knock Sensor 2 Circuit High Input (Bank 2) P0334 Knock Sensor 2 Circuit Intermittent (Bank 2) P0335 CKP Sensor A Circuit Performance P0336 Crankshaft Position (CKP) Sensor A Performance P0337 Crankshaft Position (CKP) Sensor Circuit Low Duty Cycle P0338 Crankshaft Position (CKP) Sensor Circuit High Duty Cycle P0339 Crankshaft Position (CKP) Sensor Circuit Intermittent P0340 Camshaft Position (CMP) Sensor Circuit P0341 Camshaft Position (CMP) Sensor Performance P0342 Camshaft Position Sensor Circuit Low Input P0343 Camshaft Position Sensor Circuit High Input P0344 Camshaft Position Sensor Circuit Intermittent P0350 Ignition Coil Primary/Secondary Circuit Malfunction P0351 Ignition Coil 1 Control Circuit P0352 Ignition Coil 2 Control Circuit P0353 Ignition Coil 3 Control Circuit P0354 Ignition Coil 4 Control Circuit P0355 Ignition Coil 5 Control Circuit P0356 Ignition Coil 6 Control Circuit P0357 Ignition Coil 7 Control Circuit P0358 Ignition Coil 8 Control Circuit P0359 Ignition Coil I Primary/Secondary Circuit Malfunction P0360 Ignition Coil J Primary/Secondary Circuit Malfunction P0361 Ignition Coil K Primary/Secondary Circuit Malfunction P0362 Ignition Coil L Primary/Secondary Circuit Malfunction P0370 Timing Reference High Resolution Signal A Malfunction P0371 IC 24X Reference CKT Too Many Pulses P0372 IC 24X Reference Circuit Missing Pulses P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses P0374 Timing Reference High Resolution Signal A No Pulses P0375 Timing Reference High Resolution Signal B Malfunction P0376 Timing Reference High Resolution Signal B Too Many Pulses P0377 Timing Reference High Resolution Signal B Too Few Pulses P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses P0379 Timing Reference High Resolution Signal B No Pulses P0380 Glow Plug/Heater Circuit "A" Malfunction P0381 Glow Plug/Heater Indicator Circuit Malfunction P0382 Exhaust Gas Recirculation Flow Malfunction P0385 Crankshaft Position (CKP) Sensor B Circuit P0386 Crankshaft Position (CKP) Sensor B Performance P0387 Crankshaft Position Sensor B Circuit Low Input P0388 Crankshaft Position Sensor B Circuit High Input P0389 Crankshaft Position Sensor B Circuit Intermittent P0400 Exhaust Gas Recirculation Flow Malfunction P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient P0402 Exhaust Gas Recirculation Flow Excessive Detected P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit P0404 Exhaust Gas Recirculation (EGR) Open Position Performance P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage P0406 Exhaust Gas Recirculation Sensor A Circuit High P0407 Exhaust Gas Recirculation Sensor B Circuit Low P0408 Exhaust Gas Recirculation Sensor B Circuit High P0410 Secondary Air Injection (AIR) System P0411 Secondary Air Injection (AIR) System P0412 Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1 P0413 Secondary Air Injection System Switching Valve A Circuit Open P0414 Secondary Air Injection System Switching Valve A Circuit Shorted P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction P0416 Secondary Air Injection System Switching Valve B Circuit Open P0417 Secondary Air Injection System Switching Valve B Circuit Shorted P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1 P0419 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 2 P0420 Catalyst System Low Efficiency P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1) P0422 Catalyst System Low Efficiency Bank 1 P0423 Heated Catalyst Efficiency Below Threshold (Bank 1) P0424 Heated Catalyst Temperature Below Threshold (Bank 1) P0430 Catalyst System Low Efficiency Bank 2 P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2) P0432 Catalyst System Low Efficiency Bank 2 P0433 Heated Catalyst Efficiency Below Threshold (Bank 2) P0434 Heated Catalyst Temperature Below Threshold (Bank 2) P0440 Evaporative Emission (EVAP) System P0441 Evaporative Emission Control System Incorrect Purge Flow P0442 Evaporative Emission (EVAP) System Small Leak Detected P0443 EVAP Purge Solenoid Valve 1 Control CKT P0444 Evaporative Emission Control System Purge Control Valve Circuit Open P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted P0446 EVAP Vent Solenoid Valve Control System P0447 Evaporative Emission Control System Vent Control Circuit Open P0448 Evaporative Emission Control System Vent Control Circuit Shorted P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit P0450 Fuel Tank Pressure Sensor Circuit P0451 Evaporative Emission Control System Pressure Sensor Range/Performance P0452 Fuel Tank Pressure Sensor Circuit Low Voltage P0453 Fuel Tank Pressure Sensor Circuit High Voltage P0454 Evaporative Emission Control System Pressure Sensor Intermittent P0455 Evaporative Emission (EVAP) System Leak Detected P0460 Fuel Level Sensor Circuit P0461 Fuel Level Sensor Performance P0462 Fuel Level Sensor Circuit Low Voltage P0463 Fuel Level Sensor Circuit High Voltage P0464 Fuel Level Sensor Circuit Intermittent P0465 Purge Flow Sensor Circuit Malfunction P0466 Purge Flow Sensor Circuit Range/Performance P0467 Purge Flow Sensor Circuit Low Input P0468 Purge Flow Sensor Circuit High Input P0469 Purge Flow Sensor Circuit Intermittent P0470 Exhaust Pressure Sensor Malfunction P0471 Exhaust Pressure Sensor Range/Performance P0472 Exhaust Pressure Sensor Low P0473 Exhaust Pressure Sensor High P0474 Exhaust Pressure Sensor Intermittent P0475 Exhaust Pressure Control Valve Malfunction P0476 Exhaust Pressure Control Valve Range/Performance P0477 Exhaust Pressure Control Valve Low P0478 Exhaust Pressure Control Valve High P0479 Exhaust Pressure Control Valve Intermittent P0480 Cooling Fan Relay 1 Control Circuit P0481 Cooling Fan Relay 2 Control Circuit P0482 Cooling Fan 3 Control Circuit Malfunction P0483 Cooling Fan Rationality Check Malfunction P0484 Cooling Fan Circuit Over Current P0485 Cooling Fan Power/Ground Circuit Malfunction P0500 Vehicle Speed Sensor (VSS) Circuit P0501 Vehicle Speed Sensor Range/Performance P0502 Vehicle Speed Sensor (VSS) Circuit Low Input P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent P0505 Idle Control System Malfunction P0506 Idle Speed Low P0507 Idle Speed High P0510 Closed Throttle Position Switch Malfunction P0512 Start Switch Circuit P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance P0532 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage P0533 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage P0534 Air Conditioner Refrigerant Charge Loss P0550 Power Steering Pressure (PSP) Switch Circuit P0551 Power Steering Pressure Sensor Circuit Range/Performance P0552 Power Steering Pressure Sensor Circuit Low Input P0553 Power Steering Pressure Sensor Circuit High Input P0554 Power Steering Pressure Sensor Circuit Intermittent P0560 System Voltage P0561 System Voltage Unstable P0562 System Voltage Low P0563 System Voltage High P0565 Cruise Control On Signal Malfunction P0566 Cruise Control Off Signal Malfunction P0567 Cruise Control Resume Signal Malfunction P0568 Cruise Control Set Signal Malfunction P0569 Cruise Control Coast Signal Malfunction P0570 Cruise Control Accel Signal Malfunction P0571 Cruise Control Brake Switch Circuit P0573 Cruise Control/Brake Switch A Circuit High P0574 Vehicle Speed Too High - Cruise Control Disabled P0575 Cruise Control Related Malfunction P0576 Cruise Control Related Malfunction P0576 Cruise Control Related Malfunction P0578 Cruise Control Related Malfunction P0579 Cruise Control Related Malfunction P0580 Cruise Control Related Malfunction P0600 Serial Communication Link Malfunction P0601 Control Module Read Only Memory (ROM) P0602 Control Module Not Programmed P0603 Control Module Long Term Memory Reset P0604 Control Module Random Access Memory (RAM) P0605 Control Module Programming Read Only Memory (ROM) P0606 Control Module Internal Performance P0608 Control Module VSS Output "A" Malfunction P0609 Control Module VSS Output "B" Malfunction P0615 Starter Relay Control Circuit P0620 Generator Control Circuit Malfunction P0621 Generator L-Terminal Circuit P0622 Generator F-Terminal Circuit P0650 Malfunction Indicator Lamp (MIL) Control Circuit P0654 Engine RPM Output Circuit Malfunction P0655 Engine Hot Lamp Output Control Circuit Malfucntion P0656 Fuel Level Output Circuit Malfunction P0700 Transmission Control System Malfunction P0701 Transmission Control System Range/Performance P0702 Transmission Control System Electrical P0703 Brake Switch Circuit Malfunction P0704 Clutch Switch Input Circuit Malfunction P0705 Trans Range Switch Circuit P0706 Trans Range Switch Performance P0707 Transmission Range Sensor Circuit Low Input P0708 Transmission Range Sensor Circuit High Input P0709 Transmission Range Sensor Circuit Intermittent P0710 Transmission Fluid Temperature Sensor Circuit Malfunction P0711 TFT Sensor Circuit Range/Performance P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input P0714 Transmission Fluid Temperature Sensor Circuit Intermittent P0715 Input/Turbine Speed Sensor Circuit Malfunction P0716 Input Speed Sensor Circuit Intermittent P0717 Input Speed Sensor Circuit Low Input P0718 Input/Turbine Speed Sensor Circuit Intermittent P0719 Brake Switch Circuit Low Input P0720 Output Speed Sensor Circuit Malfunction P0721 Output Speed Sensor Range/Performance P0722 Output Speed Sensor Circuit Low Input P0723 Output Speed Sensor Intermittent P0724 Brake Switch Circuit High Input P0725 Engine Speed Input Circuit P0726 Engine Speed Input Circuit Range/Performance P0727 Engine Speed Circuit No Signal P0728 Engine Speed Input Circuit Intermittent P0730 Incorrect Gear Ratio P0731 Incorrect 1st Gear Ratio P0732 Incorrect 2nd Gear Ratio P0733 Incorrect 3rd Gear Ratio P0734 Incorrect 4th Gear Ratio P0735 Gear 5 Incorrect ratio P0736 Reverse incorrect gear ratio P0740 TCC Enable Solenoid Circuit Electrical P0741 TCC System Stuck Off P0742 TCC System Stuck On P0743 TCC Enable Solenoid Circuit Electrical P0744 Torque Converter Clutch Circuit Intermittent P0745 Pressure Control Solenoid Malfunction P0746 Pressure Control Solenoid Performance or Stuck Off P0747 Pressure Control Solenoid Stuck On P0748 Pressure Control Solenoid Circuit Electrical P0749 Pressure Control Solenoid Intermittent P0750 Shift Solenoid A Malfunction P0751 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear P0752 1-2 Shift Solenoid Valve Performance - No Second or Third Gear P0753 1-2 Shift Solenoid Circuit Electrical P0754 Shift Solenoid A Intermittent P0755 Shift Solenoid B Malfunction P0756 2-3 Shift Solenoid Valve Performance - No First or Second Gear P0757 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear P0758 2-3 Shift Solenoid Circuit Electrical P0759 Shift Solenoid B Intermittent P0760 Shift Solenoid C Malfunction P0761 Shift Solenoid C Performance or Stuck Off P0762 Shift Solenoid C Stuck On P0763 Shift Solenoid C Electrical P0764 Shift Solenoid C Intermittent P0765 Shift Solenoid D Malfunction P0766 Shift Solenoid D Performance or Stuck Off P0767 Shift Solenoid D Stuck On P0768 Shift Solenoid D Electrical P0769 Shift Solenoid D Intermittent P0770 Shift Solenoid E Malfunction P0771 Shift Solenoid E Performance or Stuck Off P0772 Shift Solenoid E Stuck On P0773 Shift Solenoid E Electrical P0774 Shift Solenoid E Intermittent P0780 Shift Malfunction P0781 1-2 Shift Malfunction P0782 2-3 Shift Malfunction P0783 3-4 Shift Malfunction P0784 4-5 Shift Malfunction P0785 3-2 Shift Solenoid Circuit Electrical P0786 Shift/Timing Solenoid Range/Performance P0787 Shift/Timing Solenoid Low P0788 Shift/Timing Solenoid High P0789 Shift/Timing Solenoid Intermittent P0790 Normal/Performance Switch Circuit Malfunction P0801 Reverse Inhibit Control Circuit Malfunction P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction P1031 HO2S Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1 P1032 HO2S Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1 P1105 Secondary Vacuum Sensor Circuit P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage P1108 BARO to MAP Sensor Comparison Too High P1109 Secondary Port Throttle System P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage P1113 Intake Resonance Switchover Solenoid Control Circuit P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage P1116 ECT Signal Unstable or Intermittent P1117 Engine Coolant Temp. Signal Out-Of-Range Low P1118 Engine Coolant Temp. Signal Out-Of-Range High P1119 ECT Signal Out-Of-Range With TFT Sensor P1120 Throttle Position (TP) Sensor 1 Circuit P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage P1125 APP System P1130 HO2S Circuit Low Variance Bank 1 Sensor 1 P1131 HO2S Circuit Low Variance Bank 1 Sensor 2 P1132 HO2S Circuit Low Variance Bank 2 Sensor 1 P1133 HO2S Insufficient Switching Bank 1 Sensor 1 P1134 HO2S Transition Time Ratio Bank 1 Sensor 1 P1135 HO2S Lean Mean Bank 1 Sensor 1 P1136 HO2S Rich Mean Bank 1 Sensor 1 P1137 HO2S Bank 1 Sensor 2 Lean System or Low Voltage P1138 HO2S Bank 1 Sensor 2 Rich or High Voltage P1139 HO2S Insuff. Switching Bank 1 Sensor 2 P1140 HO2S Transition Time Ratio Bank 1 Sensor 2 P1141 HO2S Heater Control Circuit Bank 1 Sensor 2 P1143 HO2S Bank 1 Sensor 3 Lean System or Low Voltage P1144 HO2S Bank 1 Sensor 3 Rich or High Voltage P1145 HO2S Cross Counts Bank 1 Sensor 3 P1153 HO2S Insufficient Switching Bank 2 Sensor 1 P1154 HO2S Transition Time Ratio Bank 2 Sensor 1 P1155 HO2S Lean Mean Bank 2 Sensor 1 P1156 HO2S Rich Mean Bank 2 Sensor 1 P1157 HO2S Bank 2 Sensor 2 Lean System or Low Voltage P1158 HO2S Bank 2 Sensor 2 Rich or High Voltage P1159 HO2S Cross Counts Bank 2 Sensor 2 P1161 HO2S Heater Control Circuit Bank 2 Sensor 2 P1163 HO2S Bank 2 Sensor 3 Lean System or Low Voltage P1164 HO2S Bank 2 Sensor 3 Rich or High Voltage P1165 HO2S Cross Counts Bank 2 Sensor 3 P1170 Bank to Bank Fuel TrimOffset P1171 Fuel System Lean During Acceleration P1185 Engine Oil Temperature Circuit P1186 EOT Circuit Performance P1187 EOT Sensor Ckt. Low Voltage P1188 EOT Sensor Ckt. High Voltage P1189 Engine Oil Pressure (EOP) Switch Circuit P1190 Engine Vacuum Leak P1191 Intake Air Duct Air Leak P1200 Injector Control Circuit P1201 (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance P1202 (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency P1203 (Alt. Fuel) Gas Mass Sensor Circuit High Frequency P1211 Mass Air Flow Circuit Intermittent High P1212 Mass Air Flow Circuit Intermittent Low P1214 Injection Pump Timing Offset P1215 Ground Fault Detection Indicated P1216 Fuel Solenoid Response Time Too Short P1217 Fuel Solenoid Response Time Too Long P1218 Injection Pump Calibration Circuit P1219 Throttle Position Sensor Reference Voltage P1220 Throttle Position (TP) Sensor 2 Circuit P1221 Fuel Pump Secondary Circuit Low P1222 Injector Control Circuit Intermittent P1225 Injector Circuit Cylinder 2 Intermittent P1228 Injector Circuit Cylinder 3 Intermittent P1231 Injector Circuit Cylinder 4 Intermittent P1234 Injector Circuit Cylinder 5 Intermittent P1237 Injector Circuit Cylinder 6 Intermittent P1240 Injector Circuit Cylinder 7 Intermittent P1243 Injector Circuit Cylinder 8 Intermittent P1245 Intake Plenum Switchover Valve P1250 Early Fuel Evaporation Heater Circuit P1257 Supercharger System Overboost P1258 Engine Coolant Overtemperature - Protection Mode Active P1260 Last Test Failed Failed SCC ENTER:More Info. P1270 Accelerator Pedal Position Sensor A/D Converter Error P1271 Accelerator Pedal Position (APP) Sensor 1-2 Correlation P1272 Accelerator Pedal Position Sensor 2 P1273 "Accelerator Pedal Position Sensor 1 P1274 Injectors Wired Incorrectly P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit P1276 Accelerator Pedal Position Sensor 1 Circuit Performance P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage P1280 Accelerator Pedal Position (APP) Sensor 2 Circuit P1281 Accelerator Pedal Position Sensor 2 Circuit Performance P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage P1285 Accelerator Pedal Position Sensor 3 Circuit P1286 Accelerator Pedal Position Sensor 3 Circuit Performance P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage P1300 Ignitor Circuit P1305 Ignition Coil 2 Primary Feedback Circuit P1310 Ignition Coil 3 Primary Feedback Circuit P1315 Ignition Coil 4 Primary Feedback Circuit P1320 IC 4X Reference Circuit Intermittent P1321 Electronic Ignition System Fault Line P1322 EI System or Ignition Control Extra or Missing P1323 IC 24X Reference Circuit Low Frequency P1324 Crank RPM Too Low P1335 CKP Circuit P1336 Crankshaft Position (CKP) System Variation Not Learned P1345 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation P1346 Intake Camshaft Position [CMP] Sensor System Performance P1350 Ignition Control System P1351 Ignition Coil Control Circuit High Voltage P1352 IC Output High/Pulse Detected when GND_Cyl. 2 P1353 IC Output High/Pulse Detected when GND_Cyl. 3 P1354 IC Output High/Pulse Detected when GND_Cyl. 4 P1355 IC Output High/Pulse Detected when GND_Cyl. 5 P1356 IC Output High/Pulse Detected when GND_Cyl. 6 P1357 IC Output High/Pulse Detected when GND_Cyl. 7 P1358 IC Output High/Pulse Detected when GND_Cyl. 8 P1359 Ignition Coil Group 1 Control Circuit P1360 Ignition Coil Group 2 Control Circuit P1361 Ignition Coil Control Circuit Low Voltage P1362 IC Cylinder 2 Not Toggling After Enable P1363 IC Cylinder 3 Not Toggling After Enable P1364 IC Cylinder 4 Not Toggling After Enable P1365 IC Cylinder 5 Not Toggling After Enable P1366 IC Cylinder 6 Not Toggling After Enable P1367 IC Cylinder 7 Not Toggling After Enable P1368 IC Cylinder 8 Not Toggling After Enable P1370 IC 4X Reference Circuit Too Many Pulses P1371 IC 4X Reference Circuit Too Few Pulses P1372 Crankshaft Position (CKP) Sensor A-B Correlation P1374 3X Reference Circuit P1375 IC 24X Reference Circuit High Voltage P1376 Ignition Ground Circuit P1377 IC Cam Pulse To 4X Reference Pulse P1380 Misfire Detected - Rough Road Data Not Available P1381 Misfire Detected - No Communication with Brake Control Module P1390 Wheel Speed Sensor 1 - G - Sensor Circuit P1391 Wheel Speed Sensor 1 - G - Sensor Circuit Performance P1392 Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage P1393 Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage P1394 Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent P1395 Wheel Speed Sensor 2 - G - Sensor Circuit P1396 Wheel Speed Sensor 2 - G - Sensor Circuit Performance P1397 Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage P1398 Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage P1399 Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent |
Kommentare: 0
